Things to check after salvage engine swap - JeepForum.com
post #1 of 3 Old 11-23-2009, 11:26 PM Thread Starter
Morpheus
Im getting My TJ back after having my blown engine swapped for a "newer" salvage yard engine, what should I look for/check before leaving the repair facility, Im only getting a 90 day warranty so I want to check all that i could/should for piece of mind
Morpheus is offline
post #2 of 3 Old 11-24-2009, 12:34 AM
2003RubiBlue
Oil????
Ok seriously check the oil, and listen for any strange noises. I would take it on at least one long drive before the 90 days are up.
Will work for Jeep parts...
2003RubiBlue is offline
post #3 of 3 Old 11-24-2009, 03:38 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
the small print on the bill. who did your swap... reputable or questionable... do you know what and or where the motor came from? what does the "warranty" cover? motor swaps either go 2 ways... good or bad. you can probably expect to have a check engine light pop on occasionally. usually a bad sensor from the donor motor... as stated, check your oil and life fluids..listen for noises and feel for strange new vibrations.. watch your oil pressure and temp guages like a hawk for the first few trips. and do your own oil change after a few hundered miles so you can inspect the oil etc too. if it goes bad, chances are good it will happen, immediately or within the first couple hundred miles. after you get through that 'stage" with minimal or no problems.... more than likey youll be good. good luck.. hope it works out to the good for you.
ps check the A/C if your equipped, being winter and all... hate to not check it and it be in-op later.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
02 TJ D60 Axle Swap and ABS/Check Engine Lights. blt4rox TJ Wrangler Technical Forum 2 12-07-2009 07:32 PM
Salvage Engine goin in this week..... Morpheus TJ Wrangler Technical Forum 1 11-17-2009 11:13 PM
salvage d44 axle swap : pros, cons, cost jonpentium4 TJ Wrangler Technical Forum 8 04-17-2009 10:53 AM
Salvage Engine and install keithert TJ Wrangler Technical Forum 10 09-11-2006 02:16 PM
Things to check after accident waterlogged TJ Wrangler Technical Forum 17 06-28-2006 06:37 PM
