Thermostat Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Thermostat Questions
All viair onboard air systems ship free to lower 48! Www.Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEJEEP Gear Change Packages From ROCKRIDGE 4WD. We Are DIFF
Unread 08-09-2012, 09:07 PM   #1
vintagetrks
I just put a 190 degree thermostat in my 06 LJ and now I have a check engine light. How do I get the check engine light to go out? I realize that the computer is probably set for a 210 degree thermostat but I would really like my engine to run cooler on the trails. I would'nt have thought a 190 degree thermostat would have caused the check engine light to come on. Any advice would be greatly appreciated.
vintagetrks is offline   Reply With Quote
Unread 08-09-2012, 09:12 PM   #2
Unlimited04
Read tech links in my sig
Unlimited04's Avatar
why don't you pull the code and see what it says?
Unlimited04 is offline   Reply With Quote
Unread 08-09-2012, 09:25 PM   #3
06rubikon
x2
06rubikon is offline   Reply With Quote
Unread 08-09-2012, 09:29 PM   #4
vintagetrks
It gives me a code of P0118
Unread 08-09-2012, 09:38 PM   #5
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Did you plug the temperature sending unit back in?
The OEM thermostat is 195 degree...
Knuckelhead is offline   Reply With Quote
Unread 08-09-2012, 09:42 PM   #6
the_great_white
Engine Coolant temperature circuit, high input
whatever that means....
the_great_white is offline   Reply With Quote
Unread 08-09-2012, 09:51 PM   #7
vintagetrks
Yes I plugged the temp sensor back in and looked at my stock thermostat and it was a 195 degree unit. I don't know why five degrees would cause the check engine light to come on but it is. Scratching my head. Damned computer controlled stuff.
Unread 08-09-2012, 10:19 PM   #8
joe108
If you want to save your converter I would put in a 195 thermostat, if it runs too cool, it (computer)will think its cold outside and make the engine run rich, killing your cat...ask me how I know
joe108 is offline   Reply With Quote
Unread 08-11-2012, 08:37 AM   #9
TJJP77
New-Age Curmudgeon
TJJP77's Avatar
A circuit high fault can be caused by the following things according to the FSM:
  • ECT sensor voltage above 4.96 volts
  • Faulty ECT sensor
  • ECT signal shorted to battery voltage
  • ECT signal circuit open
  • Sensor ground circuit open
  • Faulty PCM
If the thermostat caused the code, I would expect a P0125 or P0128. Having said that, you should put the correct temperature thermostat in the vehicle for it to run properly and go into closed-loop operation as quickly as possible.
I would carefully check the connector at the Engine Coolant Temperature sensor - you may have a bent pin, a pushed out terminal, debris/crud in the connector causing poor contact, etc.
Chris
'02 Sahara
'06 Rubicon Unlimited
Sienna Jeep Club: Member #15
TJJP77 is offline   Reply With Quote
Unread 08-11-2012, 11:44 AM   #10
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
There is no such thing as a 210 degree thermostat for the TJ. It just runs at 210 due to the engine design but the actual factory specified thermostat is 195 degrees.
You can reset your CEL by disconnecting the right-most connector to your PCM, the one closest to the engine for 2 minutes and then reconnecting it. Make sure it clicks back into position. That saves having to disconnect the battery and losing your clock and radio presets.
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Unread 08-11-2012, 03:38 PM   #11
erockz
Did you happen to start the jeep with the temp sensor unplugged? Even just for a short period of time, it would cause the code to set.
erockz is offline   Reply With Quote
Unread 08-11-2012, 06:55 PM   #12
Unlimited04
you can get 205° thermostats....
look up STANT Part # 13352
