Is there a write up on how do install a TT? - Page 2 - JeepForum.com
post #16 of 24 Old 08-04-2007, 07:47 PM
Scotch740
Scotch740's Avatar
Originally Posted by cb19950
thanks for the pics...mine looks different than yours
Humm what does yours look like?
Hopefully not like this.
The one in my installed pics is the same as the one you linked earlier. So unless something got messed up it should be working. Keep in mind I did cut off the original pieces with the holes in them and redrilled the holes 1" closer in.
Scotch740 is offline
post #17 of 24 Old 08-04-2007, 08:00 PM
kd4yor
Ya just need one of these from TF. makes everything go slick as snot
I don't have enough lift to "stuff a tire"
kd4yor is offline
post #18 of 24 Old 08-04-2007, 08:13 PM
Scotch740
Scotch740's Avatar
Whats TF? What is that piece? Looks like it goes on the TC but I don't really get what benefit it would be. Problem with a TT is space.
post #19 of 24 Old 08-04-2007, 08:20 PM Thread Starter
cb19950
TF is tera flex
2000 TJ
When we do right, no one remembers. When we do wrong, no one forgets.
cb19950 is offline
post #20 of 24 Old 08-04-2007, 08:22 PM Thread Starter
cb19950
ya i ment in the t-case stuff dosnt look the same to me lol...to install it what all did u need to pull or remove
2000 TJ
cb19950 is offline
post #21 of 24 Old 08-04-2007, 08:22 PM
kd4yor
TF made a shortened bell crank to allow the linkage to work. That is a picture of the piece.
kd4yor is offline
post #22 of 24 Old 08-04-2007, 08:43 PM Thread Starter
cb19950
how hard was that piece to install...and i have a 1" BL any chance i could get away without having to use one?
2000 TJ
cb19950 is offline
post #23 of 24 Old 08-04-2007, 08:48 PM
kd4yor
Probably by relocating your shifter pivot bracket. The part is snap fit.
kd4yor is offline
post #24 of 24 Old 08-04-2007, 08:59 PM Thread Starter
cb19950
sry for my lack of knowledge but im not quite sure what u mean...could i get away from running any type of bracket or relocator
2000 TJ
cb19950 is offline
write up for trans install? mattiemo TJ Wrangler Technical Forum 0 12-19-2008 11:01 PM
ZJ spring install write up badoosh27 TJ Wrangler Technical Forum 11 10-30-2007 07:06 PM
Anyone have an a/c install write up? chaznad TJ Wrangler Technical Forum 2 10-06-2005 11:10 PM
Re install tech write-ups DogHouse TJ Wrangler Technical Forum 1 04-12-2004 12:03 PM
write ups on EZ Locker INSTALL? jackal TJ Wrangler Technical Forum 1 01-27-2004 10:03 AM
