Is there a way to clear engine codes? - JeepForum.com
post #1 of 11 Old 09-16-2009, 12:16 PM Thread Starter
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
Is there a way to clear the engine codes besides pulling the (-) off of the battery and letting it sit for a while>?
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
'04 QC LB Cummins 4x4
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline
post #2 of 11 Old 09-16-2009, 12:20 PM
Alexia
Alexia's Avatar
Go to an automotive store that reads codes for free and they would be able to do it for you.
2004 Jeep Wrangler Unlimited, Automatic
RC 2.5" Lift - RC 2.5" Rear Track Bar Bracket - JKS 1.25" Body Lift - JKS Front Disconnects - JKS 1" Budget Motor Mount Lift - Spidertrax 1.25" Spacers -
Power Door Locks with Keyless Entry
Alexia is offline
post #3 of 11 Old 09-16-2009, 12:30 PM
Jeepster83
X2. but disconnecting the negative terminal requires less time overall.
disconnect the cable, go pee or something, go hook it back up.
vs
get in the Jeep, drive to autozone, go somewhere else because they dont do that anymore, get it cleared, drive home. and the entire time youre driving to the right place you have to see the engine light on.
the former sounds much easier to me.
Being right has nothing to do with arrogance. It's only perceived that way by those that are wrong.
WyoTech West Sacramento - Graduated 8/19/2011
Back into my Jeep... finally.
Jeepster83 is offline
post #4 of 11 Old 09-16-2009, 12:30 PM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Pull the negative cable off for a minute or two.All you have to do afterwards is reset your clock and radio stations.No big deal.
TheBoogieman is offline
post #5 of 11 Old 09-16-2009, 12:31 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you could buy a ScangaugeII. it will clear codes
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #6 of 11 Old 09-16-2009, 01:37 PM Thread Starter
JeepRocks86
well I would rather not have to buy anything, since i'm already planning on buying an OBD I cable and software so I can work on my 95 suburban and make some "adjustments" and repairs.
For Sale:
post #7 of 11 Old 09-16-2009, 01:39 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Then you're left with disconnecting the battery for 1-2 minutes.
Jerry Bransford is offline
post #8 of 11 Old 09-16-2009, 01:52 PM
FirmusArma
x2
I love my scangauge II. The mileage calculations and digital gauges are all fine and dandy, but its real nice to be able to pull up the codes at anytime and/or clear them. The time it has saved me so far has made it well worth it
FirmusArma is offline
post #9 of 11 Old 09-16-2009, 02:19 PM
ksm279
Try turning your key on and off 3 times quickly, shouldprovide the fault code and there is a list of code on the site here.
Whoops, this will only read the codes off, not clear them!
ksm279 is offline
post #10 of 11 Old 09-16-2009, 02:26 PM
Unlimited04
Post #1 - you asked if there was a way to clear codes without disconnecting the battery, to which I replied you could buy a ScangaugeII.
and now we're back to disconnecting the battery. if you don't want to disconnect the battery then the only other option is to take the Jeep to a shop where they will gladly take your money to clear the code.
Personally, I'd just unhook the battery
Useful Write-Ups:
Funny:
post #11 of 11 Old 09-16-2009, 08:17 PM Thread Starter
JeepRocks86
the only reason I was asking is because on my OBDI if I press the accelerator and the brake at the same time, it clears the codes.
For Sale:
Engine Codes???? dallass YJ Wrangler Technical Forum 2 07-02-2009 08:28 PM
FAQ - Check Engine Light and Diagnostic Trouble Codes (Error Codes, Problem Codes) Wheelin98TJ TJ Wrangler Technical Forum 6 05-15-2009 05:05 PM
Can I clear the check engine light on my 97 TJ by disconnecting a battery cable? mebmoseley TJ Wrangler Technical Forum 6 08-31-2008 12:36 PM
Clear codes 21&51? Marc A YJ Wrangler Technical Forum 2 11-27-2007 08:17 AM
Engine Codes idgit0488 TJ Wrangler Technical Forum 2 10-10-2005 03:49 PM
