Drilling? You'll need to drill if you add a trackbar relocation bracket in the rear. Welding it on is another option if you don't want to drill. As for the front, no real need to drill unless the particular trackbar comes with a larger bolt, like my jks did. I had to drill the frame mount hole slightly larger to fit the larger bolt. It was a 2 min drilling job.
I got the front adjustable track bar from rubicon express which still required drilling the front frame mount hole to accommodate a slightly larger bolt. If you don't want to drill, make sure you ask if the mounting bolt is the same diameter as the stock bolt for the bar that you order.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.8K members
Since 2000
