Quantcast Is there any disadvantage to installing a 1" body lift and 1"M.O.R.E motor mount lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Is there any disadvantage to installing a 1" body lift and 1"M.O.R.E motor mount lift
Old 01-16-2003, 05:43 PM   #1
DLoweinc
before I get tires?
I am in a MOD mood. Just ordering the parts may quench my desire for a week but the urge to mod will definetly rise..
98 Grand Cherokee... Jack Stands, no front axle... Working seat belts!
DLoweinc is offline   Reply With Quote
Old 01-16-2003, 05:51 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The only caution I can offer in installing the 1" talller M.O.R.E motor mounts is to maybe have some patience in installing them if you haven't already installed the suspension lift. The taller motor mounts will increase the transfer-case to driveshaft angle in the opposite direction that installing a new lift does... which without the lift to counteract and move that angle an equal but opposite direction, could cause vibrations.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 01-16-2003, 05:58 PM   #3
DLoweinc
OK, maybe I will just purchase them and then wait ..
Would I be subject to vibrations (based on what I've read from this forum, it seems to be hit or miss, some have them some don't) if I did the 1" body lift/motor mount lift and a 2" coil spacer lift?
Would the spacer lift also cause the same increase in the transfer-case to driveshaft angle in the opposite direction that installing a new lift does?
Old 01-16-2003, 06:28 PM   #4
Jerry Bransford
I doubt it. The 1" motor mount kit will more than offset the minor vibrations you may receive with a 2" coil spacer lift.
No, a spacer lift (the 2" suspension spacer kit you are asking about, right?) would cause the same increase in transfer case to driveshaft angle that a new lift causes. So a 2" spacer lift will cause the exact same increase in that angle that a 2" coil spring lift will cause. Is that what you meant?
Getting Savvy...
Old 01-17-2003, 10:49 AM   #5
DaRaidz
We just added the MORE kits two weeks ago. Our TJ was already set up with the Old Man Emu Suspension system. The MORE motor mount lift added a significant amount of engine vibration. This seems to be getting a little better with time but still feels like a tank when you start it up. I've heard this is from the harder rubber in the mount itself, but it is SIGNIFICANT IMO. The kit was a little tricky to get installed. If you do a search on this forum you will see some hints and tricks others have used to get the mounts lined up. There is a problem with the alternator bolt on the passenger side hitting the mount. If they had only put the bolt facing the other way it would've been no problem.
I really like the added lift and we removed the Tcase lowering pucks that came with the OME lift, so we gained another inch of clearance. No tcase vibes, but the engine vibes are rough. The added body clearance has made a big difference in off roading as well.
'86 CJ7 I-6, 5 speed, 33 Pro Comp, BDS lift, CD, Hardtop and Doors, 4X Dr. Rockers, 4.88 gears, ARB Air Lockers front and rear, Dana 44 rear, 63K original miles...very sweet rig.
DaRaidz is offline   Reply With Quote
Old 01-17-2003, 11:08 AM   #6
Jerry Bransford
I'm betting you installed MORE's polyurethane motor mount kit, right? Any polyurethane motor mount will do that. I replaced my old Currie polyurethane 1" taller motor mounts earlier this year (one broke) with MORE's rubber motor mounts. Vibrations introduced by the Currie polyurethane mounts are gone now, the engine now feels much smoother now, much like it did before the Currie mounts were installed.
So DLoweinc, I recommend you install the rubber version of MORE's engine mounts, you'll be much happier with them. They're a little more money but well worth it in my opinion.
Getting Savvy...
Old 01-17-2003, 11:11 AM   #7
Jim Shanks
I've had about the exact same expierience as DaRaidz, except I am running Daystar 1" MML. Sometimes I feel like I went back in time and am sitting in a hotrod with solid steel motor mounts. Shakes da hell out of things. Oh well though, it's a Jeep, not a cadillac.
Jim
"Cracked Cow" '01TonTJ2a, Solid Mfg HP60's, 5.38's, ARB's, PSC full hydro, 14" coilovers, ASD roof and doors, armored everywhere sitting on 40" Iroks.
Subscribe to CRAWL
Jim Shanks is offline   Reply With Quote
Old 01-17-2003, 11:17 AM   #8
Jerry Bransford
Makes sense, Daystar uses nothing but polyurethane in all of their products which is excellent at transmitting noise and vibration. I've become very disillusioned with polyurethane for most things in a Jeep if you can't tell.
Getting Savvy...
Old 01-17-2003, 06:10 PM   #9
DLoweinc
the bombproof MORE mounts don't give that vibration right?
Old 01-17-2003, 06:18 PM   #10
quadna71
i have the bombproofs - didn't get any vibes as a result - actually, they eliminated the vibes that my 2" spacer lift had induced. can't speak for the poly ones, but the rubber ones rock.
chris
2003 TJ Sport - mine, 2001 TJ SE - hers
2001 XJ Sport - ours, 1987 XJ Chief - ours
2000 TJ Sport - sold, 1993 XJ Sport - totaled
1987 XJ Laredo - sold, 1953 CJ-3B - sold
quadna71 is offline   Reply With Quote
Old 01-17-2003, 06:37 PM   #11
dan58
I just installed the 1" MML and 1" BL (both by MORE) on my 03 TJ. The MML install isn't the easiest, but managable. I would HIGHLY suggest installing the Advanced Adapters t-case shift kit at the same time! For an extra $40, you cannot go wrong.
BTW, I have vibes too.
2003 TJ Sport
Medic bellyup
RE 4.5SF, SYE&Woody
33x12.5-15 TSLs
4.56s, Lockright & Detoit
dan58 is offline   Reply With Quote
Glock Forum
