Quantcast Teralow too low? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Teralow too low?
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-TJ 5.25" Speaker Adapters - NalinMFGFree Shipping on TIRES at KrawlOff-Road
Old 08-05-2006, 08:16 PM   #1
tjteo
Teralow too low?
Here in Greece the trails are mixed. Mud and rocks.
Lot of people say that 4:1 reduction in TC is too low for mud.
What do you people thing? will my 3rd gear -after the install
of Teralow- be like the 2nd now? Because we use a lot the 2nd!!!
Thanx in advance!!!
tjteo is offline   Reply With Quote
Old 08-05-2006, 08:21 PM   #2
tjteo
2.5L-4,88 R&P-35s for now.
These might help you.
Old 08-05-2006, 08:40 PM   #3
Stu Olson
Stu Olson's Avatar
In the AX-5 tranny:
1st gear = 3.93:1
2nd gear = 2.33:1
3rd gear = 1.45:1
The NP-231 t-case's low range is 2.72:1
The Tera t-case mod makes low range 4.0:1
From here, it is easy to do the math.....pick the tranny gear ratio and multiply it by t-case ratio. Then you can compare which gear with which t-case is nearly the same as another gear with the other t-case.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is online now   Reply With Quote
Old 08-05-2006, 08:48 PM   #4
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
I don't think 4:1 is too low at all. With a 2.5L I don't think it's possible to be geared too low
When I'm on the trails I use 4LO exclusively, and if I need more wheelspeed for a mudpit or something, I just throw it in 6th. The only time I got stuck I blame on my small MTR's
I need a 35" tire for spare. PM me if you have something.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Old 08-05-2006, 08:50 PM   #5
tjteo
I believe that i won't have a problem using the 3rd gear instead of the 2nd.
Thanx a lot Stu. Your site is GREAT
Old 08-05-2006, 08:53 PM   #6
Stu Olson
Stu Olson's Avatar
You are welcome....and thanks. I hope it all works out for you.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Old 08-05-2006, 08:53 PM   #7
tjteo
I agree. But Teraflex says not to use 5th gear.I think
Old 08-05-2006, 09:07 PM   #8
Stu Olson
Stu Olson's Avatar
You need to keep the input shaft speed of the Tera low t-case to 3,000 RPM or less.
That means you could use 4th gear at 3,000 RPM on the engine tach....or you could use a little more PRM if in 3rd gear, and still more in 2nd, gear, etc.
I agree....I would not (and never did) use 5th gear with my Tera low and it was a not very common for me to even use 4th gear (unless it was on a flat section of ground, no rocks, no mud, nice easy going).....and then I wouldn't push it much more than 2K or 2500 RPM.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Old 08-05-2006, 09:12 PM   #9
tjteo
The stock TC gears do not have such an issue. Do they?
Old 08-05-2006, 09:14 PM   #10
neZZr
neZZr's Avatar
Good question. How about the 241's gears?
The only thing in the manual is they tell you to keep speed under 35mph in 4LO... maybe that makes sense for a 231, but the engine would really be screaming with 4:1 gears
SIRA 4x4 club
Old 08-05-2006, 09:15 PM   #11
Stu Olson
Stu Olson's Avatar
No they do not.....it is a limitation of the Tera gears.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Old 08-05-2006, 09:16 PM   #12
Stu Olson
Stu Olson's Avatar
I don't believe you could achieve 35 MPH with the 4:1 t-case.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Old 08-05-2006, 09:18 PM   #13
neZZr
neZZr's Avatar
iAgree. Rev-wise that'd be equivalent to 140 in top gear
But I still wonder if there is a similar input limitation.
SIRA 4x4 club
Old 08-05-2006, 09:29 PM   #14
paultyler
Uncle Paul has spoken...
paultyler's Avatar
I have a Teralow with 4.88s as well. With my four banger it is great on most trails. And it is good in mud too. I mean how often do you really go through mud so deep that you have to fly across the top? You can always start off in 2 or 3rd and floor it to get the tire speed up. With the Teralow you can get your RPMs higher than 3,000 but you should not for very long.
By the way, my top speed in 4Lo 5th gear is about 20 if I get my RPMs to 3,000.
My Jeep - Video
My Jeep in the Snow
92 YJ, 35' MTR Kevlars, Klune/Dana 20, 4.88s, SYE, Rubicon D44s w/Rubicon lockers, front and rear Alloy USA chromoly shafts with 30 spline outers, JK electric swaybar, T&T tube fenders, custom cv driveshafts, RE 4.5 XD springs, M.O.R.E. 5/8'' boomerang shackles + 2' BL, 15lb Powertank, 4.0L TB & TB spacer, ARB Snorkel, K&N filter, rear bumper and tire rack, Rancho 9000s, AtoZ Rockers, Skid-Row Engine skid plate, Teraflex Bellyup, JCR Offroad 1 Ton TieRod, rock lights, RE hand throttle, M.O.R.E. roll cage, corners, 9000lb winch with synthetic cable in-cab winch controller (12voltguy.com), Dual Blue Top Optimas with 12voltguy dual battery controller, a/c (ackits.com)
Originally Posted by joshrad View Post
This Uncle Paul guy seems to know what he's talking about.
paultyler is offline   Reply With Quote
Old 08-05-2006, 09:37 PM   #15
tjteo
You are right. I don' t do mud bogging.
Only incline muddy paths in the forests.
I suppose it will be ok.
Glock Forum
