Quantcast Teralow for NP231 survey - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Teralow for NP231 survey
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 09-05-2009, 09:40 AM   #46
pachary
I don't really care what the criteria for input speed is other than if there is a restriction, that is enough argument to get a 241 instead with NO restrictions. Price is negligable as is difficulty of installation.
Paul
http://i242.photobucket.com/albums/ff220/pachary/Beasley120107/Beasley121-37.jpg
2005 TJ Unlimited/I6-M6/Rubi 4:1 Tcase/4.5RESF/1.25JKS BL-1BMML/37"SSRs/WarnM8000/Besttop TireCarrier/Waggy D44/ FR-RR DetroitD44/Cobra Remote CB/custom F&R Bumpers/JeeperMan Skids/York OBA/Rokmen TummyTuck/TNT 3" Fenders and Rear Corners/AA SYE- Carolina Drivelines CV Shaft
pachary is offline   Reply With Quote
Old 09-05-2009, 10:36 AM   #47
alecmcmahon
alecmcmahon's Avatar
I would go with a 241, but i have a 4 cylinder with AX5 Transmission that a 241 will not mate up to, So my options are limited.
-my build thread-
alecmcmahon is offline   Reply With Quote
Old 09-05-2009, 12:10 PM   #48
Boodyrider
Originally Posted by 2000TJDude View Post
I am thinking to upgrade my transfer case to a Teralow and 2LOW kit in the "off season" and was wondering what you all thought. I have read several threads on the topic and am aware that I could also try and find a Rubi case and swap it. Thoughts????
Rubi case is good, but no 2LO. By the time you rebuild the 231, pay for 2Lo and the TeraLow, and beef up the internals with the wide chain and good planetary... the Rubi is cheaper. By far.
But for the best of all worlds, and to never again have to worry about strength... Atlas 4 speed. Sure it's 3 grand, but it'll give you EVERY possible gear ration you'll need for 99.99% of ALL wheeling you'll do.
OR... JB Conversions 231HD, add a KluneV
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Old 09-05-2009, 07:19 PM   #49
elkfan2
elkfan2's Avatar
x2 and never look back. Cable shifters come up through factory shifter location, one little one inch hole had to be drilled by e-brake handle, and didn't have to modify tranny tunnel for the 4 speed to fit either.
elkfan2 is offline   Reply With Quote
Old 09-05-2009, 09:44 PM   #50
mferrari
DelmarvaOffroad.com
mferrari's Avatar
I've been running the teralow in my 231 for a while now and I beat the snot out of my Jeep. No problems so far. We will see how well it holds up to comp use this year...
Michael Ferrari
TJ Based Buggy <BUILD THREAD>
Team 120 - DOR Racing - Racing for Operation Homefront
Thanks to our Sponsors:
Delmarva Offroad - F-O-A Shocks - BD Turnkey Engine - Under Cover Fab - Jer-C Transmissions - Quigley Driveshafts
Operation Homefront (OHF) provides emergency financial and other assistance to the families of our service members and wounded warriors.
Delmarva Offroad
You call it rolling, we call it R&D! 443-951-JEEP
mferrari is offline   Reply With Quote
Old 09-06-2009, 02:05 AM   #51
solarpower
While I love an Atlas...there is still quite a bit more work involved in putting one in than a Rubi NP241OR.
Pound for pound..penny for penny the 241 easily wins for a TJ. Going to +37" tires, D60's, V8 conversion..then go Atlas.
78 CJ5
04 TJ "U" package
06 XK Commaddy
Jeep mods do not fix poor driving or stupidity.
solarpower is offline   Reply With Quote
Old 09-06-2009, 10:27 AM   #52
elkfan2
elkfan2's Avatar
Like what kind of work? Mine bolted right in.
Old 09-06-2009, 10:35 AM   #53
JeSimmers
JeSimmers's Avatar
I thought all you had to do was swap the transmission ouput shaft in order to mate a 241 up to the AX5...this is just a thought, I may be completely wrong.
Red Jeep Club Member #454
1998 ZJ - The wife's
1997 TJ - Mine
JeSimmers is offline   Reply With Quote
Old 09-07-2009, 08:40 PM   #54
BillR
BillR's Avatar
Mine did also. No cutting or even massaging the tub. It was completely a bolt-in project.
'05 LJ Sport, 6-speed, SwayLoc, LoD bumpers...the build begins!
'11 JK Unlimited Sport S, stock for now...
BillR is offline   Reply With Quote
Old 09-07-2009, 08:52 PM   #55
elkfan2
elkfan2's Avatar
Gotta love the internet wheelers that no all huh?
Old 10-15-2009, 07:16 PM   #56
Srgslaughterav
Srgslaughterav's Avatar
OK I have to add to this for the fact of not starting another thread. I HATE TERAFLEX products and will not buy anything else from them again. I searched the threads and apparently didn't search for "problems with tera low kit" or I would have found this before my problem. I bought the darn tera low kit and after about 25 miles of trail riding and 50miles of highway driving after the install. I realized that all the oil had leaked out of the t-case from the input shaft. I tore out the t-case to find that the freeze plug had not been installed right. Manufacture problem because this we don't touch during the install. It is inside the planetary gear set just behind the female splines on the t-case.
YouTube - freeze plug movement inside of teralow kit 2
YouTube - movement of freeze plug inside planetary gear set of teralow kit 1
They gave me the run around with reasons not needed to be disgused. They wanted to me to fill the hole up with silicone and be done with it. I was not happy with this response so I called up Quadratec witch is who I bought it form and told them what had happened. They said they would take care of it and send me a new kit. 2 weeks later and I have not recieved my kit yet. So I called Quadratec costomer service. Keith took my call. He had to call teraflex to get a tracking number. After getting the run around from teraflex he found out that they did not send one yet. So quadratec had one in stock and is going to send it to me overnight at no cost to me. Chalk one up for Quadratec I can't pick a fight with them. But unfortunatly still stuck with teracrap for my jeep. Hopefully this one will last long enough to get some use out of it before I can justify going with the Atlas. Hope this helps someone else in the future.
4" short arm lift, Anti rock sway bars front and rear. hard rock Front and rear bumbers, Warn 9.5ti winch,Undercover fab engine and tc skid,genright extreme gas tank, AtoZ Fabrication rocker guards, metal cloak fenders all around,JKS bar pin elminators, Viair Extreme Duty OBA system, Cobra CB, 37'' iroks on trailready beadlocks , NP231 Novak shifter tera low 4:1 with 2 low kit and SYE , CV ds, rockjock 3 front and rear dana60's with front and rear ARB with 4:88's.PSC hydro assist
Srgslaughterav is offline   Reply With Quote
Old 10-16-2009, 07:04 AM   #57
BillR
BillR's Avatar
If it were ME (and this is what I did!), I'd sell the replacement teracrap products without even reinstalling it. Save up a little coin and get a DURABLE t-case so you don't have to do the job again.
Old 10-16-2009, 08:16 AM   #58
2000jeeper
I plan on installing one also when i do my SYE and tcase rebuild. From what i heard they are nice
AMSOIL DEALER
2000jeeper is offline   Reply With Quote
Old 10-16-2009, 08:23 AM   #59
elkfan2
elkfan2's Avatar
For the cost that 4:1 kit and the SYE you almost buy an atlas.
Old 10-16-2009, 08:26 AM   #60
Srgslaughterav
I guess you haven't read this thread from the beginning. Please don't buy a tera low kit. Junk. Like I had stated earlier that if I would have seen this thread before buying and installing one I would not have in the first place.
I am contimplating it.
Glock Forum
