Quantcast Teralow? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Teralow?
JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff PartsJeep CJ, YJ, and TJ build your own bumper packages.
Old 09-27-2006, 03:27 PM   #1
1234JeepinJordan
Teralow?
Are they worth getting? I have a 4 cyl and plan on getting 4:88s. will the Tera Low make it the gears run too low?
[COLOR="Blue"][B]Blue Jeep Club Member #196[/B][/COLOR]
1234JeepinJordan is offline   Reply With Quote
Old 09-27-2006, 03:29 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
That's a great ratio if you rock crawl and Tera's kit has been out for a long time with a lot of happy users. I'm between it and an Atlas II, though I know which would be the better choice between those two.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 09-27-2006, 03:31 PM   #3
UCTJ
The Tera low will only affect your low range crawl ratio, when your tcase is in 2hi your gears will be like normal ie...not reduced. So depeding on your trans you can figure your crawl ratio out like this.
1st gear ratioxaxle ratioxtcase low range=
Do the same for both with and without Tera low to figure your final crawl ratio if I had a Tera low mine would be 80.83, since I dont its 53.62.
So no it wont make your gears run too low if your doing rockcrawling its a perfect setup....
UCTJ is offline   Reply With Quote
Old 09-27-2006, 04:44 PM   #4
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Yeah, the Teralow kit is pricey... not nearly as much as an Atlas II, though with that you're getting a much stronger case at the same time.
The Tera kit is probably the better choice for most, especially behind a 4cyl.
To answer the question of too low... not likely. With 4cyl power, you want it as low as you can get, because as was mentioned it only affects your lo-range gear reduction... not 4HI or 2WD.
I need a 35" tire for spare. PM me if you have something.
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote
Old 09-27-2006, 04:47 PM   #5
Jerry Bransford
The reason I keep the Atlas II in mind is because selling my NV231 t-case will help reduce the net cost of the Atlas. Plus if he has a SYE kit installed like mine does, that ups its value considerably to those who need a SYE kit but either can't or are doubtful they could install it. This makes it priced a little more competitively to the Tera 4:1.
Getting Savvy...
Old 09-27-2006, 05:31 PM   #6
UCTJ
Very true...but one will need to keep in mind the front driveshaft will either need to be lengthened or get a new one since the lengths are different if I recall correctly so some added cost with the Atlas some dont think about. Between the two Id rather have the Atlas either way you cant go wrong....and as Jerry said if you already have an SYE it will up the value when you sell it to offset the cost of the Atlas.
Old 09-27-2006, 06:25 PM   #7
hvac59
The 2lo is something that had to be factored in when I went with the Tera. It's utility in my application is very important. It adds about $200 and makes it even closer in price to the Atlas II. Some forget to factor that in, is why I'm bringing it up ! Sorry if my opinion is "no opinion"
hvac59
White 01 WJ (stock 4.7 limited)
White 08 MK Patriot (minor mods) -SOLD-
Looking for a White (ultralite?) project Jeep -FOUND-
White 09 JK "X"
hvac59 is offline   Reply With Quote
Old 09-28-2006, 10:01 AM   #8
tjgoose
My Tera Lo was one of the best mods I have made to my Jeep. It is pricey, but in my case, I didn't have the coin to re-gear and lock and the Tera got me closer to where my low range needed to be. I will still re-gear when the money is found. My crawl ratio will be about 80:1 when that is done, but I can actually function in low range with the R&P I have now.
And when you have the case cracked open, install the 2-lo as well. For the money, you'll regret it if you don't. The whole case can be torn out rebuilt and re-installed in an afternoon.
'02 /RE 3.5 springs / Clayton LA / JKS 1.25" BL / M.O.R.E. 1" MML / SwayLock / Tera Low 2- Low / D30 with 4.56 & ARB / D44 with 4.56, 35 spline Alloy & ARB / 36" Iroks on Trail Ready Beadlocks / Shrockworks Rockers / 33 Engineering Belly-up / AA SYE and TW CV / Currie Steering / TNT fenders Corners / CJ Mirrors / RE Hand Throttle / Uniden Pro 510XL & Firestik
tjgoose is offline   Reply With Quote
Glock Forum
