Teraflex upper front control arm std length mounting? - JeepForum.com
post #1 of 1 Old 07-26-2010, 12:14 PM Thread Starter
Lemmiwinks
Anyone else using the Teraflex upper front monster style control arms (std length)?
About to mount a pair up and wanted to double check regarding which way the frame end is mounted. The frame end mount contains a triangle shape and they don't provide directions to what direction the angle is to be mounted (up or down)?
I called Teraflex and the person I spoke with couldn't remember.
Lemmiwinks is offline
teraflex , uca , upper , front , length , direction , tj , wrangler , suspension
Rear upper control arm length dodgetk81 TJ Wrangler Technical Forum 7 08-01-2011 10:22 PM
where to get teraflex upper control arm bushings? Blackjackbender TJ Wrangler Technical Forum 2 09-11-2009 09:07 PM
need length of stock front upper control arms neverbackdown TJ Wrangler Technical Forum 6 04-02-2009 10:41 PM
adj upper rear control arm length? RJV TJ Wrangler Technical Forum 3 03-14-2009 05:59 PM
Front Upper Control Arm Length P89Jeeper TJ Wrangler Technical Forum 1 10-09-2007 03:09 PM
