Teraflex Tera low vs. NP231 read here! - JeepForum.com
post #1 of 61 Old 02-04-2011, 09:54 PM Thread Starter
RockRodHooligan
RockRodHooligan's Avatar
So while I've been building up my NP231, I was given 2 Tera 4:1 cases, both of them were trashed(thus free). I decided to pull one of the Tera cases the rest of the way apart to look a little closer as to what happened. Both tera cases had the same failures at the planetary gear set, here is why:
Here is the Tera case ring gear that the planetary gear rides in:
231 case:
Planetary gears: Tera on the left, 231 on right
Tera, 5 pinion:
231, 3 pinion:
The pinion that fell out of the Tera planetary set, and the shaft that is supposed to hold it in place
RockRodHooligan is offline
post #2 of 61 Old 02-04-2011, 10:37 PM Thread Starter
RockRodHooligan
This is the problem I see with the Tera 4:1, the smaller straight cut gear is all that rides on the ring gear in the case, the larger helical cut gear rides on the inner gear(sun gear?)
But there is nothing on the opposite side of either of those gears to help support large torque loads. The straight cut gear is pushed in by the ring gear, and the helical gear is pushed out by the sun gear(may not be the right name for it, but thats what I'm going to call it until someone corrects me), causing large amounts of stress on the shaft that holds the pinion in place. EVERY ONE of the pinions on the Tera planetary gear had large amounts of play, the shafts probably don't look too much better than the one that fell out, there was so much play, that the pinions barely make contact with the sun gear as it turns.
The 231 planetary set has much wider contact surfaces, the ring gear, pinions, and sun gear, are all the same width, so the ring gear supports full width of the pinion under heavy torque loads from the sun gear, and vice versa. I do not have a detailed pic of the 231 planetary gear, but you can get an idea of it from the pics above, I'll take some more pics of it tomorrow and post them up.
post #3 of 61 Old 02-04-2011, 10:42 PM
03GoldTJ
Very interesting!
03GoldTJ is offline
post #4 of 61 Old 02-04-2011, 11:10 PM
lclark2074
lclark2074's Avatar
wow alot of damage!!!
night crew 226
lclark2074 is offline
post #5 of 61 Old 02-05-2011, 10:34 PM Thread Starter
RockRodHooligan
NP231 planetary pinion and sun gear:
post #6 of 61 Old 02-05-2011, 11:19 PM
EricsGreen98Tj
sub. Was thinking of the Terra low option in the distant future, now i dont know.....
Building my junk with more junk, so Im always on the look out for more junk....Free to cheap preferably. :D
My junk http://www.jeepforum.com/forum/f22/survivor-project-driveway-frame-swap-33s-build-1280626/index3.html
EricsGreen98Tj is offline
post #7 of 61 Old 02-06-2011, 07:06 AM
BillR
BillR's Avatar
Mark me down as another Jeeper that's NOT impressed with the TeraLow. I had one, and it sounded like a piece of misadjusted farm equipment in low range. The Atlas that replaced it is much quieter and WAY stronger.
'11 JK Unlimited Sport S, stock for now...
'08 JK X, OEM rear locker and swaybar disco!
BillR is offline
post #8 of 61 Old 02-06-2011, 07:11 AM
rob78
Very interesting post. Thanks for taking the time to do this.
rob78 is offline
post #9 of 61 Old 02-06-2011, 10:59 AM
pcoplin
Yes, Tera sucks. Welcome to 2003.
FullStack MotorSports
pcoplin is offline
post #10 of 61 Old 02-06-2011, 11:04 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
That damage might have been caused by over-revving the planetaries by driving at higher speeds in 4Lo than recommended. Too many drive in 4Lo at higher speeds than is good by shifting into 3rd or even 4th gear which REALLY revs up those planetaries gears, they are screaming at those rpms.
Jerry Bransford is online now
post #11 of 61 Old 02-06-2011, 11:37 AM
BillR
BillR's Avatar
Agreed!
BillR is offline
post #12 of 61 Old 02-06-2011, 11:43 AM
williambmac
I originally considered the Tera case, but deicided against it after reading alot of not not-so-great reviews.
I ended up getting a good deal on a rubi case and couldn't be happier.
2000 TJ 5.5 Long arm, lots of extras. R.I.P.
2005 LJ rubi 35's Clayton, lots of extras
williambmac is offline
post #13 of 61 Old 02-06-2011, 11:48 AM
EricRollerSkate
Could be one of the very few aftermarket drivetrain products that I actually think the quality of stock looks way better.
Lowered, Dubbed, and Spinning
Why wear a flip flop on your left foot, and a steel toe on the right?
EricRollerSkate is offline
post #14 of 61 Old 02-06-2011, 12:38 PM
Robert J. yates
Not really vouching for Tera as I had my go around with them years ago but the Tera case in my truck is 10 years old and has never caused me any grief. Now the first case I got from them exploded within 500 miles of installing it and I had a friend with a similar experience but this second case has worked out really well for me. Jerry does make a good point about over-revving the case... it's not built for that style of driving.
Originally Posted by samgm2 View Post
And yes, I am an exceptional scientist and engineer.
Robert J. yates is offline
post #15 of 61 Old 02-06-2011, 12:47 PM
MO2500
Interesting info. Thanks for sharing. I too was considering one for my 231 someday but might just save for a while longer and get an atlas later on down the road.
Instagram: @omsmike
MO2500 is offline
Tera 2LO kit for NP231? ROUGHSHOD TJ Wrangler Technical Forum 19 10-05-2009 06:57 PM
NP231 Tera Low 4:1 conversion OR Atlas II sprowley YJ Wrangler Technical Forum 11 09-14-2009 05:46 PM
If you're using Teraflex track bars, read this. JeepMan1975 JK Wrangler Technical Forum 0 08-15-2007 06:13 PM
NSG370 6spd. w/NP231 Tera Low 4.0:1? anybody make it yet? KennyTJ TJ Wrangler Technical Forum 5 06-20-2007 07:34 AM
Tera 2-low kit for NP231 Want24Wheel TJ Wrangler Technical Forum 11 02-06-2007 12:17 AM
