teraflex swaybar disconnects - JeepForum.com
post #1 of 3 Old 01-16-2011, 01:49 PM Thread Starter
nwco4x4
I was reading that the teraflex swaybar disconnects have a bracket to relocate the brake lines. I am running about 5 inches of suspension lift total. Are these brackets good enough to flex with the sway bar disconnected or will I still need extended brake lines
nwco4x4 is online now
post #2 of 3 Old 01-16-2011, 02:00 PM
biffgnar
biffgnar's Avatar
I ran those Tera brackets and would only be comfortable with them at 2-3 inches lift. Higher than that I'd go to YJ lines.
Romney in 2020!
biffgnar is online now
post #3 of 3 Old 01-18-2011, 02:30 PM Thread Starter
nwco4x4
with a 4 inch lift will yj brake lines be long enough at full flex with the swaybar disconnected. also are the a direct swap in or is the modification to be made.
swaybar disconnects? Blackbart TJ Wrangler Technical Forum 16 11-04-2009 09:53 PM
Swaybar disconnects: Teraflex vs. JKS JFranko YJ Wrangler Technical Forum 18 07-31-2009 06:42 PM
Swaybar disconnects cbrspdfrk TJ Wrangler Technical Forum 21 03-23-2004 11:58 PM
swaybar disconnects? 4wheelinfool YJ Wrangler Technical Forum 4 02-07-2003 10:09 PM
swaybar quick disconnects jks or teraflex??? sahara55 TJ Wrangler Technical Forum 4 01-08-2002 09:51 PM
