TeraFlex or RE and State Laws - JeepForum.com
post #1 of 7 Old 07-11-2004, 04:23 PM Thread Starter
elmo510
elmo510's Avatar
i have been looking around and have narrowed my choices down to the Teraflex 3" super lift or the RE 3.5" super flex kit. what i am really wanting to do is put on some 33x12.5 tires for some weekend wheeling. i have heard some bad stories about the teraflex control arms so would i be better off getting the basic lift and buying a diffrent brand control arm. would i need the sye kit for either of these lifts? Also i live in the state of VA and i believe the law for lifts with jeeps is the bumper can't be higher than 23", would these lifts with a 33 tire put me over this. and does anyone have pics of these lifts with 33 tires.
Thanks
elmo510 is offline
post #2 of 7 Old 07-11-2004, 06:57 PM
StealthTJ
Thanks
- Regarding the lift law, check and be sure, don't rely on "I believe...."..
It would be a shame to spend money on something that you can't install.
- Regarding the bumper height with those two lifts and 33" tires:
* First, take 1/2 the diameter of your existing tires subtracted from the 33's. For instance, if you're running 30's now you'll use 1 1/2" -> (33 - 30) = 3 3/2 = 1 1/2"
* Next, if you're looking at the RE3.5" lift, and the above tire measurement to 4.5" ~ 5.0". If you're looking at the Tera lift, use 3.5", added to the tire measurement from above
* Lastly, measure your existing bumper height and add that number to it, and you'll have your new bumper height.
You don't need either of those two lifts to run 33's, nor would you need new control arms. The OME lift with a small spacer (3/4" ~ 1") lift plus a 1" ~ 1 1/4" bl will handle 33's, and provide a ton of flex, while maintaining a probable better than stock on and off road ride.
Fred
Base - '98 Sahara, 4.0L 6 cyl, Auto (swap from 5 sp)
Suspension- 4.0" Procomp Springs + 1 1/4" bl. Rear tri-link. Currie J arms, F&R. Warn hubs with WJ knuckles, custom cross over/hi-steering setup, Currie A/R Sway Bar.
HPD30/D44 (rear disk conversion, WJ dual piston caliber conversion in the front); Detroits; 4.56
Misc - Tera 2wd lo.
Tires - 35x12.50 MT/R's siped on 15x7 Champion Beadlocks.
Recovery - Warn XD9000i
StealthTJ is offline
post #3 of 7 Old 07-11-2004, 07:01 PM
doorocks
doorocks's Avatar
I know it's not 23 inches. Stock Full sized pickups are that high. Va. is right around the 30" mark. Probably a little less.
LIFE IS TOUGH ENOUGH ALREADY, IT'S EVEN TOUGHER WHEN YOU'RE STUPID.
RE 3.5 and all kinds of other relevant goodies, you know winch and stuff.
Life is like walking into the No Chance Bar full of Future Darwin Stories........
More mods than a hillbilly's set of teeth..
doorocks is offline
post #4 of 7 Old 07-11-2004, 07:26 PM Thread Starter
elmo510
elmo510's Avatar
In VA there are two diffrent catagories one for trucks and one for passanger vechicles which jeeps fall under, so for some reason it is higher for trucks
elmo510 is offline
post #5 of 7 Old 07-11-2004, 10:36 PM
kizer
kizer's Avatar
Found this a while back.
http://www.truckworld.com/How-To-Tec...lift-laws.html
1600+ Write-ups, and more
kizer is offline
post #6 of 7 Old 07-12-2004, 05:53 PM
rkutzner
rkutzner's Avatar
In MD I called the state highway safety office and the very helpful officer pointed me to the IN PRINT ONLINE Maryland COMAR Regulations. In MD Jeeps are listed and tagged as 'multiuse' vehicles along with trucks. Bumper height 26". Full tire covered. Regulations of the size and type of wood required for wood bumpers (hehehe....really...)
I'm at 24.5-25" with my RE 4.5 LA , 35" MTRs, and winch. The officer in MD said all they really are concerned about is people using reputable lift companies and not 'designing' their own.
But get it in print.
2001 TJ Sport
Everything SELF INSTALLED.
The Serious Stuff:4.5 RE LA, 35" MT/Rs, 4.88s, Super44 w/Detroit, D30 w/Ptrax, SYE, Tera 4:1, 2LOW & Rear Disks, AntiRock, Lotsa Skids (some homemade!), Nth Shock Shifters, Patriot 9500...and LOTS more !
rkutzner is offline
post #7 of 7 Old 07-12-2004, 05:58 PM
gabemerrill
gabemerrill's Avatar
just got mine inspected in Hampton Va... I've got 7 inches of lift and 36 inch tires (with stock flares) and they didn't say anthing at all about it.
HTH - Gabe
'99 TJ - True 44s w/4.56 Detroits & USA Alloy up front, 4.5/3.5 RE SF, AtlasII 4.3, Hydro assist High steer, Armor Cage n' Stuff
gabemerrill is offline
Door laws, state to state idencustom Wrangler General Discussion 34 04-20-2017 02:50 PM
Lift laws: state by state kaybone Wrangler General Discussion 11 04-09-2009 04:31 PM
====LIST of STATE MIRROR LAWS==== dz1087 Wrangler General Discussion 6 07-09-2008 10:41 AM
NJ State Windshield Laws 95GreenWrangler Wrangler General Discussion 22 06-22-2008 01:44 PM
state laws bashbro YJ Wrangler Technical Forum 14 12-22-2007 10:05 PM
