teraflex lower monster control arms install question - JeepForum.com
post #1 of 3 Old 07-25-2010, 06:04 PM Thread Starter
Lemmiwinks
Purchased a used set of Teraflex monster control arms (lower rear) and not sure which end gets mounted to the axle? Flex end or the bushing end? Also does the grease fitting point up or down?
Also any feedback regarding your experience with maintaining them?
Lemmiwinks is offline
post #2 of 3 Old 07-25-2010, 07:24 PM
del_TJ
I had the same ones installed as rear lowers at Elia's 4WD to adjust my rear pinion angle. Rubber bushing end is on the axle, and the grease fitting points up. No problems after 1 year - don't even notice they're there. Grease them regularly.
del_TJ is offline
post #3 of 3 Old 07-25-2010, 10:16 PM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
the reason most companies offset the axle end, is because the shock mount on the axle overhangs so much that if it were just welded on there straight, it would bind up sooner and do more damage than good. plus there is more welding surface area when they are welded at an angle = stronger.
Mail crawling.
MisfitSeven is offline
teraflex , lca , rear , bushing , direction , advice , help
Lower Control Arms Install Question quattrogato TJ Wrangler Technical Forum 8 06-05-2009 12:31 PM
Lower Fixed Control Arms vs adjustable lower contol arms jeep2005ride TJ Wrangler Technical Forum 5 03-20-2009 01:23 PM
Lower Control Arms Install Problem Michigan Outlaw TJ Wrangler Technical Forum 4 04-11-2008 07:56 AM
8.8 install, control arms question.. House TJ Wrangler Technical Forum 9 02-19-2008 01:37 PM
Teraflex Control Arms---Good Or Bad? GA TJ TJ Wrangler Technical Forum 8 06-15-2005 09:38 AM
