tera quick disco's - Page 2 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > tera quick disco's
Raceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-GearTJ Dana 60 - BOLT IN REAR
Unread 02-25-2003, 08:38 PM   #16
Tango
Originally posted by Dalerus
Umm you talking about the thing the clip hooks into? Because I am 99% sure they face inward.
Heres what mine look like.
He does have the dissconnect in backwards though. Those Zerks are supossed to go the other way
uhhh what to do , what to do ? do yours rub Dalerus when you disco? and I was pretty sure my Zerks were right I will have to see if I can find the instructions laying around.
anybody else agree or disagree on wich way is right?
[url]http://www.mpjai.com[/url]
02 TJ 4.5" of lift , Locked Both ends, with 4.56's pushing 33X12.50 MTR's
[URL=http://rigs.mpjai.com/detail.php?siteid=11]2002 TJ [/URL]
Tango is offline   Reply With Quote
Unread 02-25-2003, 08:40 PM   #17
Dalerus
http://www.4wheeln.com/SWAYBAR/
Check out the direction his face.
No rubbing here.
[B]Green Jeep Club Member #9[/B]
Dalerus is offline   Reply With Quote
Unread 02-25-2003, 08:46 PM   #18
Dalerus
http://www.stu-offroad.com/98jeep_lift/tj_lift2.htm
LOL I guess he didn't know either!
He says he called the shop but I just got off the phone with my shop, they said I had them facing the right direction! Ack!
Unread 02-25-2003, 08:50 PM   #19
cptn_mrgn78
Mine are mounted like Dalerus, no problem here.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline   Reply With Quote
Unread 02-25-2003, 09:05 PM   #20
Tango
based on my directions I think mine are right .....but mine rub and yours don't..... I will look at mine tomorrow and see what I can see. but as far as the stud , I have mine on right. the directions read - "Insert the stainless steel stud in the whole vacated by stock sway bar arm so that the threaded end of the stud points away from the vehicle"
can't belive I found my directions after all this time
I dont really see what the Zerks matter unless it affects the way sway bar arm fits on the stud??
Thanks again guys
we will get this figured out
Unread 02-25-2003, 09:21 PM   #21
Dalerus
Ya, it seems to me that the direction the Zerks face should not make a difference.
Unread 02-25-2003, 09:28 PM   #22
Bucket110
i hate to change the topic back to the original one on my post but can some one answer this quickly and then we can get back to the new topic...thanx....
since im going with a 2" bb, should i get the 0-2" ones or the 2-5" ones??? i am planning on going with either a 3.5" or 4.5" lift longer down the line.
2002 TJ Blk, 4.0, 5spd, dual top/doors, Dana 30/44, 6", 35's, 4.88s, locked f/r, air, KC lights, CB, PSC rockers/cage/corners, m8000, flat fenders, custom front bumper, TXT rear
2003 F350 diesel....tow rig
[COLOR=blue]NEJEEPZ[/COLOR]
[URL=http://community.webshots.com/user/2k2blktj]My Jeep[/URL]
Bucket110 is offline   Reply With Quote
Unread 02-25-2003, 09:31 PM   #23
Dalerus
Someone gave you a number to call.
If it was me I would WAIT untill I got the new lift.
I see you have home made ones now. Wait until the new, bigger lift comes in. You know what they say, if it ain't broke...
Unread 02-25-2003, 09:38 PM   #24
Bucket110
ok...thanx
Unread 02-26-2003, 02:15 AM   #25
dejablu311
I wasn't aware that they made more than one size. I got mine a little less than a year ago and I don't think they have changed them since then. I am pretty sure they just come in one size. They say it is for a 2-4" lift but the guys at Tarheel 4WD in charlotte said that they will actually fit 0-4" lifts. Oh and don't worry about the .5" difference between 4.5 and 4.0. Its the same height lift. The weight of your vehicle makes a bigger difference.
2000 Sahara that is for sale.
dejablu311 is offline   Reply With Quote
Unread 02-26-2003, 09:41 AM   #26
Dalerus
Nope they make two sizes. I have the 2"-5" because after my stock ones broke I knew I would be going bigger down the road so I went with the ones I wouldn't need to replace.
