Temp shot up to just in the red in drive through - JeepForum.com
post #1 of 2 Old 08-04-2010, 12:05 PM Thread Starter
shdwtek
Went through the drive through, bunch of cars, so stop and go. Started driving away, and noticed the temp was just in the red zone. I was going to pull over, but then it started to drop back down to normal.
It's about 85 degrees (f). Is this something I should be concerned about? I let it idle for a bit when I parked, and it pretty much just stayed a little past half way.
Edit: Just checked the reservoir, and there is almost no coolant in it. I've checked for leaks, but I don't see any.
shdwtek is offline
post #2 of 2 Old 08-04-2010, 02:59 PM
scottbr
2016 JK Wrangler
Could be either a fan clutch going bad or air in the cooling system. Or both.
After it cools completely check the rad level.
scottbr is offline
coolant , temp , temperature , red , idle , tj , wrangler
Temp guage shot ? LMG23 TJ Wrangler Technical Forum 3 06-21-2010 08:15 PM
Surface temp vs. internal temp InEmberClad YJ Wrangler Technical Forum 2 01-07-2010 07:04 PM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 10:01 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 10:41 AM
Diff yoke shot, how far can I drive on only front axle? beady YJ Wrangler Technical Forum 6 07-09-2006 04:43 PM
