Is this temp normal? Temp Gauge Pic !!! - JeepForum.com
post #1 of 24 Old 06-16-2007, 12:42 PM Thread Starter
Thunderstrike
Thunderstrike's Avatar
2009 JK Wrangler
I am running 1/8" or 3/16" pass the 210 mark when driving city or highway with outside temp > 90'. I remember my TJ staying right at 210 first couple of years, but now runs a little hot.
How is your temp reading? I'm concerned a bit since I'm driving to El Paso this July.
2009 JK Rubicon
Shrockworks Mid-width, Warn 9.5Ti; Skid Row Engine Skid, LCA & Evaporator Skid; Rock Hard Gas Tank Skid; Warn Stainless Steel Diff Skids, 11,000# Pull-Pal. Uniden 520XL CB; 1" Front & 1/2" Coil Spacer Rear; Aeroforce Interceptor, Valentine 1.
Moab - TJ-4/2006, TJ-5/2008, 4/2009, 5/2011, 4/2013, 5/2016, 4/2017
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Thunderstrike is offline
post #2 of 24 Old 06-16-2007, 12:45 PM
lj_wil
ekorb mi
lj_wil's Avatar
My temp is just on the cold side of 210
W6FU
lj_wil is offline
post #3 of 24 Old 06-16-2007, 12:48 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Your cooling system might be getting a little restricted from something, perhaps hard water deposits. Have you been mixing hard tap water with the antifreeze which will eventually cause mineral deposits inside the radiator?
Gone on vacation until August 25.
Jerry Bransford is offline
post #4 of 24 Old 06-16-2007, 12:56 PM
AlTheKillerr
AlTheKillerr's Avatar
mine is always just under 210
Photographer
AlTheKillerr is offline
post #5 of 24 Old 06-16-2007, 01:33 PM
elephant ride
Buz around a field a few times?
Agreed it's like asking if you have gas in your tank when it won't start so you did look at the radiator right?
Probably chemical flush time but I've had grass seed blockage and almost got stranded..lol "oh that's what those screens are for"
elephant ride is offline
post #6 of 24 Old 06-16-2007, 02:52 PM
Ozzy817284
I have an 01 wrangler, mine from time to time goes a hair above the 210. I changed out the 5 year antifreeze and it still does it. I'm not to worried about it. when i see it hit half way between the 210 and 260 thats when its getting a little too hot and i'll worry about it.
Ozzy817284 is offline
post #7 of 24 Old 06-16-2007, 05:19 PM
happycamper
1986 XJ Cherokee
mine runs a hair above the 210, actually the needle sits in the center of the 0 when I'm on the freeway, but on the streets and the trail it sits rite at 210
Gone but not forgot. 2000 Sahara 4.0, auto, 4"rock krawler x factor long arm, 33x12.50x15 M.T. Mtz, M.T. classic lock rims,30/44 limited slip, land runner safari rack, land runner front, and rear bumpers, warn 8000i winch, cobra cb, jks 1.25" bl, brown dog 1" mm lift.AA sye, J.E. Reel drive shaft, Aussie locker, Rock Crusher front cover
happycamper is offline
post #8 of 24 Old 06-16-2007, 07:46 PM
tctrjeep
We hit 100 degrees ambient today. Ours was sitting on the right edge of the 0 - which is 235 degrees according to our AutoXray EZ-Scan 6000. It was working hard going uphill at over 6000 feet, and we have a few items in front of the radiator.
When going downhill it was at or just under center.
We are exploring some additional cooling options.
Emergency Communications & SAR Project Jeep
We have a new Domain! Find us at:
tctrjeep is offline
post #9 of 24 Old 06-16-2007, 09:08 PM Thread Starter
Thunderstrike
2009 JK Wrangler
I always use distilled water, and recently reduced to 35% antifreeze 65% water mixture. I never wheeled in mud, but can wash radiator at a car wash with high pressure water to see what happens. I've put in a new 195' thermostat and high flow t-stat housing, but no improvement. I've also tested viscous fan and it seems to be working good -- I hear loud roaring when hot and only turns a little when I try to turn if by hand with engine off.
Seems like we both run a little hot at 235' at times. Let me know how it turns out from your cooling options.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #10 of 24 Old 06-17-2007, 01:35 PM Thread Starter
Thunderstrike
2009 JK Wrangler
Yeah, come down South and you'll hit it there.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
post #11 of 24 Old 06-17-2007, 01:37 PM
Marn
Station Wagoneer
Marn's Avatar
1973 FSJ Wagoneer
I sit right at about 210 or a hair above when wheelin the TJ here in the 105 degree desert....
-Andrew
Illegitimi Non Carborundum
The Beast Build Thread:
Marn is offline
post #12 of 24 Old 06-17-2007, 03:15 PM
bluejeep00
i put in a 180 termaste and mine stays right around 190, i run starit water. the temp here in yuma is at 110 degerres already.
00 TJ
3" lift kit coil spacers in the front
63mm throttal body and spacer
33 12.50 15 turxes mt's on 15 by 10 steel rims
cut fenders tuffy overhead cb no backseat
looking for any cheap parts
bluejeep00 is offline
post #13 of 24 Old 06-18-2007, 02:33 PM
kavanji
2009 JK Wrangler
My Jeep does the same, winch and large lamps are the cause got a bit better after the body and mm lift
V51JP
Dirt, Rocks, Mud...Whatever
White Jeep Club Member #183
kavanji is offline
post #14 of 24 Old 06-18-2007, 08:19 PM
EHUPP01
EHUPP01's Avatar
Same here in El Paso only its not that HOT Yet.
In Memory
"Lets Roll"
EHUPP01 is offline
post #15 of 24 Old 06-18-2007, 08:32 PM Thread Starter
Thunderstrike
2009 JK Wrangler
I ordered 3-row metal HD radiator from Radiator Barn today.
May be my Superwinch is blocking airflow to my radiator, so since the 3-row is HD and provides 10-25% more cooling with even larger core than 2-row, may be this will fix 15-20 degree hotter running temp when driving > 45 mph.
Last thing I need is to have overheating problem when traveling across Texas this July.
2009 JK Rubicon
Ouray - TJ-8/2007
Rubicon - TJ-9/2008
Temp gauge spike while driving, normal at idle andwes03 TJ Wrangler Technical Forum 6 08-15-2009 01:12 PM
Normal Operating Temp?? Daylan TJ Wrangler Technical Forum 3 07-19-2009 10:46 PM
What is the normal engine temp? snooop1e YJ Wrangler Technical Forum 13 06-19-2007 11:49 AM
210 Normal Operating TEMP...? Ryzen TJ Wrangler Technical Forum 21 01-22-2007 09:57 AM
Normal Water Temp? Leroux YJ Wrangler Technical Forum 8 08-14-2006 04:49 PM
