Temp gauage - JeepForum.com
post #1 of 3 Old 07-19-2010, 11:24 AM Thread Starter
brodon
Temp gauage
Hey guys, I just started noticing that my temp gauge has been moving a bit lately. I can't say if it has always done this and i just didn't notice, or if something is actually wrong. It only goes up a little bit, the needle will go just past the middle dot. Anyway, my question is does this happen to any of the rest of you, or should i start diagnosing it for a problem? Please dont start suggesting potential problems, as i am fully capable of that, i am simply wanting to find out if it is still in the normal operating range. Thanks!
LJ owners member #275
brodon is offline
post #2 of 3 Old 07-19-2010, 11:36 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
A/C on? outside temp? time duration? any heat soak due to traffic conditions? mileage? have you flushed the coolant? if so, did you use HOAT?
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 3 Old 07-20-2010, 02:08 AM
oakmckinley
Mine stays at 210 when driving, but it can move a little if I am stuck in traffic on a hot day only about a needle width over.
1999 TJ
2010 Mustang
1964 Ford Fairlane 500
oakmckinley is offline
temp , temperature gauge , moving , tj , wrangler , help , advice
Surface temp vs. internal temp InEmberClad YJ Wrangler Technical Forum 2 01-07-2010 07:04 PM
AC blowing hot--temp dial in cold, but temp dial was previously in hot greendot200200 TJ Wrangler Technical Forum 6 11-14-2008 07:26 AM
Is this temp normal? Temp Gauge Pic !!! Thunderstrike TJ Wrangler Technical Forum 23 06-26-2007 10:01 PM
Temp Sensor / Coolant Temp Sending Unit malone_ge YJ Wrangler Technical Forum 1 03-01-2007 10:41 AM
need and answer to and old question. (gas gauage) jerico TJ Wrangler Technical Forum 6 09-25-2006 09:16 PM
