Temp Control Cable Stuck - JeepForum.com
post #1 of 5 Old 03-28-2005, 09:05 AM Thread Starter
4cyl
4cyl's Avatar
Trying to work out some bugs in my new used TJ
So, my AC was blowing boiling air - I tested the system - its fully charged.
(Please no flames about the AC - its hot in Fla in a shirt and tie)
So I read on here it could be the blend air door. Sure enough I detached the cable and the push the door and ice cold air comes out.
Now, I re-attached the cable and it goes back to hot because the cable wont go abck into positon. It feels stuck. Any suggestions besides just leaving the door on the AC setting?
1997 SE
4-banger-hampster-squirrel
Moss Green
Pavement Ends Spice Soft Top
31in Goodyear MT/R
Moab Wheels
Sound Bar
4cyl is offline
post #2 of 5 Old 03-28-2005, 09:33 AM
wherndon
What the hell?
wherndon's Avatar
don't know if this will help, but you should check and make sure the cable doesn't have any real sharp bends as it makes it way back to the control panel.
Maybe someone install an aftermarket stereo, or something, that is interfering with the cable.
________________________________
'05 Rubi, Patriot Blue, RE SF, Antirock, Warn, Fabtech, Tomken
_________________________________
2000 Grand Cherokee Laredo V8, Patriot Blue
Stock
'93 YJ Sport, Canyon Blue
4.0, auto, air, limited slip, HT.
2.5" Rancho suspension, Ramsey 8000
Previous Jeeps...
'91 XJ Laredo, white
'87 YJ Sport, white
wherndon is offline
post #3 of 5 Old 03-28-2005, 11:23 AM Thread Starter
4cyl
4cyl's Avatar
it moves to a certin point - then simply wont go further. But if I pull on it, it goes just the inch further to close air blend door to heat. hmmmm
1997 SE
Moss Green
31in Goodyear MT/R
Moab Wheels
Sound Bar
4cyl is offline
post #4 of 5 Old 03-28-2005, 11:25 AM
wherndon
What the hell?
wherndon's Avatar
may have a kink in it somewhere.
you can also try some graphite lubricant in it.
Stock
Previous Jeeps...
'87 YJ Sport, white
wherndon is offline
post #5 of 5 Old 03-28-2005, 11:49 AM
ncb76
ncb76's Avatar
Pull the climate control panel. Look where the cable attaches to the slide. Is the cable bent? Is it splayed? Any time I've had that problem, the cable gets kinked or splayed and wont slide into and out of the sleeve. A dry lubricant may help.
Also, check under the glove box. The cable routes that way and is exposed for a time before it goes back into a sleeve.
"Let Freedom, Friendship, Faith thy Soul Engage,
And serve, like them, thy country and thy age."
'97 TJ Sport | 2" Spacer Lift | JKS Disconnects | RS 5000's | 32x11.5 ProComp MT's on MT Classic II's
ncb76 is offline
Looking for heater control cable clips drew2000 YJ Wrangler Technical Forum 16 06-03-2009 05:19 PM
Temp Slider Cable JayFi TJ Wrangler Technical Forum 1 09-28-2008 09:30 PM
tempature control cable needs replaced, I NEED HELP mick883 YJ Wrangler Technical Forum 6 05-15-2008 08:29 PM
heat temp control cable? ylojelo YJ Wrangler Technical Forum 7 01-19-2006 03:03 PM
Heater (temp control cable?) issue proc YJ Wrangler Technical Forum 6 11-29-2004 08:38 PM
