Quantcast Tell me if this sounds like a good idea or not for rust prevention. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Tell me if this sounds like a good idea or not for rust prevention.
Old 09-12-2009, 08:35 PM   #1
BWFBezerk
When I change my oil I plan on putting the used oil into a spray bottle and coat the underside of the Jeep. So a 5 quart oil undercoat every 5000 miles, that sound ok? Should stop bushing squeaks and the such also.
BWFBezerk is offline   Reply With Quote
Old 09-12-2009, 08:42 PM   #2
HMUSN
no it doesn't sound like a great idea honestly.
as soon as first rain hits your Jeep will cover the road in oil.
HMUSN is offline   Reply With Quote
Old 09-12-2009, 08:43 PM   #3
Boodyrider
Also, it'll attract all kinds of dirt and crap, and deteriorate all the rubber bushings too.
Undercoat or clean and hit with bedliner material, proper lube, far better idea.
97 TJ Sport - 4.0/HP D30 w ARB/8.8 w LS/4.88s; 35s and flat fenders on 2.5 lift
84 CJ7; frame off restoration in progress.
The technical advice you get from me here is worth exactly what you paid me for it. Warranty issues will be reimbursed at double what you paid me for the advice.
Boodyrider is offline   Reply With Quote
Old 09-12-2009, 08:49 PM   #4
BWFBezerk
I also thought that it would attract dirt, so I sprayed a section of my frame with it already and since it's been on a week it is actually cleaner than the rest of the frame.
Old 09-12-2009, 08:49 PM   #5
mikesbeachhut
YOU my friend would make you a environmental terrorest.
mikesbeachhut is offline   Reply With Quote
Old 09-12-2009, 08:52 PM   #6
BWFBezerk
then what does the make the YJ folks lol
Old 09-12-2009, 09:07 PM   #7
NH2112
I've known people who've done this with good results, you just spray using a garden sprayer and park on old blankets or something til it stops dripping after a few days.
Phil
No more Jeep.
'88 F350, 2WD, 7.3l diesel, 5-speed, crew cab, SRW, flatbed. Right around 450K miles on it.
NH2112 is offline   Reply With Quote
Old 09-12-2009, 10:03 PM   #8
EvilM0nkey
This is the silliest idea i've ever heard.
EvilM0nkey is offline   Reply With Quote
Old 09-12-2009, 10:13 PM   #9
BubbaGoose
It's an old one.
Used to see the old farts do it when I was a kid.
( 60's & 70's )
What they didn't use on the vehicle
went to the back fence to kill weeds.
Although I have had some Fords that had it as a factory option
never felt like purposely gunkin' my vehicles up like that.
BubbaGoose is offline   Reply With Quote
Old 09-12-2009, 10:48 PM   #10
Bishop Creek
Originally Posted by BubbaGoose View Post
It's an old one.
( 60's & 70's )
Ah, the good 'ol days. I remember back in the early '60s helping my Dad dump his used oil into a dug hole in the backyard.
“This isn’t the Old West, because the New West has never arrived. It’s just the West, like Wyatt Earp died yesterday.”
─ Michael Martin Murphey talking about the Eastern Sierra during an interview in 1996.
Bishop Creek is offline   Reply With Quote
Old 09-12-2009, 10:52 PM   #11
cuder
World Class Painter
cuder's Avatar
You should spray the inside too, makes it ez to get in and out.
cuder is offline   Reply With Quote
Old 09-12-2009, 11:12 PM   #12
mattiemo
you're better off buying a can of wd-40 and spraying that on the under side. (oil all over the place is just a pain to work on and more mess then it's worth) JMO
mattiemo is offline   Reply With Quote
Old 09-12-2009, 11:17 PM   #13
Kiwi Jeeper
It's an old one.
( 60's & 70's )
I think back then used oil was diluted with diesel (or kerosene oil) and then sprayed (and no I am not that old, nor do I have personal experience).
Personally, I wouldn't do it. A lot of the rubber components do not particularly like oil on them. Also sprayed oil on the exhaust would not smell nice when hot.
'01 TJ Renegade I6 4.0L Auto D30/D44, BFG Muds, Currie springs, OME shocks, Brown Dog MML, ARB Front and Rear Bars, Rokmen Gas tank skid and LCAs, RE UCAs, JB Conversion Super Shorty with Truspeed and TW shaft, Warn 9.5xp
'03 WG Limited V8 4.7L stock standard
Kiwi Jeeper is offline   Reply With Quote
Old 09-12-2009, 11:21 PM   #14
FarFire70
Sounds like you already have your mind made up.
I'd have to agree that it's an environmental nightmare. Tread Lightly!!! That includes your day-to-day life too.
Wire brush off any current rust and give the entire undercarriage a good coating of rustoleum (or POR-15 if you want to spend the money). Then just keepng up with any rust that forms would be much better solution. I'm currently in the process of doing this to mine and makes the Jeep look much better
Villanova Wildcat!
2005 Wrangler Sport, 4.0L, 6spd
2" BB, JKS 1.25" BL & MML, M/T MTZ 33x12.50R15
HP D30: Aussie Locker, D44: Eaton Elocker
FarFire70 is offline   Reply With Quote
Old 09-12-2009, 11:41 PM   #15
XXRider
Used motor oil is too thin to be a good undercoating.
Friends of mine use a mix of hydraulic fluid, grease and used motor oil to under coat and it works great. It's applied with the same sprayer used for box liners.
*****TJ Tech BOOT CAMP***** A must-read for new TJ owners/forum members
XXRider is offline   Reply With Quote
Glock Forum
