TCC Circuit Malfunction P0740 Code - JeepForum.com
post #1 of 1 Old 12-27-2011, 12:23 PM Thread Starter
Redleg13
Hey guys need some help. I drive a 97TJ automatic transmission with a 4.0. My check engine light came on and it read a P0740, which I understand is the TTC circuit Malfunction. Well I checked my transmission fluid and it was about a pint and a half low. I filled it and took it for a test drive. The only problem that I could feel was at about 60mph it did not want to shift when I accelerated rapidly. The RPMs were at about 3,500. Later it started shifting fine. Should I reset the code and see what happens?
Redleg13 is offline
Need help for code P0740 & clear code fail. rpman TJ Wrangler Technical Forum 18 12-05-2012 06:30 PM
P0740 TCC Enable Solenoid Circuit Electrical - TCC is torque converter clutch. DesertJeep2002 TJ Wrangler Technical Forum 6 04-03-2009 07:32 PM
Engine Code P0740... Torque Converter Clutch Circuit... Has Anyone dealt with this? DesertJeep2002 TJ Wrangler Technical Forum 1 04-03-2009 07:24 PM
P0740 - Torque Converter Clutch Circuit Malfunction jeepman44 TJ Wrangler Technical Forum 1 11-12-2007 02:23 PM
TCC Circuit Malfunction???? Mudder69 TJ Wrangler Technical Forum 17 10-30-2004 02:51 PM
