Quantcast taraflex 1" body lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > taraflex 1" body lift
Old 02-12-2008, 10:05 PM   #1
e-tek
got a tara flex 1" body lift and installed it but i have one problem. it says to put the shift linkage bracket on but i cant seem to see where it goes anyone got any idea?
1998 green TJ with a 2" bb LIFT.
4.3l v6
e-tek is offline   Reply With Quote
Old 02-12-2008, 10:06 PM   #2
Rocky529
Jeep
Rocky529's Avatar
Do you have trouble shifting into 4WD?
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Old 02-12-2008, 10:09 PM   #3
e-tek
i just put it on two seconds ago i pulled a bracket off from under the carpet in the cab it was four bolts. but it said to take off another one. a mounting bracket but i dont know where it is
4.3l v6
Old 02-12-2008, 10:12 PM   #4
Rocky529
Jeep
Rocky529's Avatar
You have to crawl under and remove the linkage from the bracket that is bolted to the tub that you just loosened.
Don't touch it unless you have trouble shifting into 4WD even if the directions do say to install it.
Old 02-13-2008, 09:39 AM   #5
Shorty
I only needed the new bracket when I was running the T-case drop and 1" BL. With just my 1" Teraflex BL I only needed to "adjust" The linkage a bit. Works fine.
Who lives in a pineapple under the sea?
"Horrendously scratched black jeep club member #7"
(w/ Hurculined accents)
Shorty is offline   Reply With Quote
Glock Forum
