The tale of Tom turkey and my Jeep
| Great deals on Mickey Thompson Tires @ Jeephut.com | RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com | Poison Spyder Brawler Rockers! |
#1 | |
I am driving up Stateline Road not far from the house. Many deer and turkey are in the area. There is a hill on the right and a sharp drop off on the left. As we all know, turkeys do not fly well. Naturally, tom turkey launches himself to try to make across just as I am halfway up the hill. He is clearly not going to make it so I brace for impact. I figured my windshield was smashed. He made it past the windshield and my drivers side mirror took the brunt of the impact. Ever since the mirror will not stay in place. Anyone have an idea as how to tighten it? I have peeled back the rubber housing and see no way to tighten it. TIA.
[COLOR=DarkOliveGreen]#116[/COLOR] [QUOTE=XJIceQueen98;3719459]and on that note.. i'm going to play with them till i fall asleep[/QUOTE] [QUOTE=micifus] Its like a little voice in side your head constantly saying Boobs, Boobs, Boobs, Boobs. Sometimes I am able to silence it with rational thought but in the end it always makes a more clear, rational argument. Boobs.[/QUOTE] |
#2 |
sounds like part of the housing may have gotten cracked causing it to be loose. I dont see any other reason it would be. Was it damaged like that at all?
#3 |
No damage before or since. It moves freely for adjustment but it will not stay in place.
#4 |
I have the same problem with my drivers mirror. When the doors are actually on, anyhting over 50 mph and the wind normally pushes the mirror flat. Maybe the po hit a turkey too...
#5 |
If you got the old school YJ/TJ mirrors, pull the accordian style boot down and tighten the two phillips srews.
#6 | |
#7 |
I hope you ate that SOB.
#8 |
on my 2000 wrangler there are 2 parts to the mirror that move the one right on the door that only moves foward and back and then the part thats out a little further that lets you move the mirror in all directions.. wich part is not staying ?
if its the part right next to the door just try to tighten the nut under neath or spray some pb blast let it soak abit and take it appart there is actually a spring in there clean the spring up some times they get oxidized like crazy and wont compress any more because its full of gunk and thats why it wont hold the mirror still because its stuck compressed.. if its the swivil point i beleve there are two screws on the bottem of the mirror see if they are snug and if they are the plastic cup inside the mirror probably is broken and you will most likely need to replace the mirror. good luck. |
#9 | |
#10 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
