Quantcast T-Case Shifter Mod - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > T-Case Shifter Mod
Old 04-30-2007, 07:40 PM   #1
BluesMan
T-Case Shifter Mod
Got tired of the stock shifter set-up on my 01 TJ. (ok bored, and can not leave anything alone)
Shifts great and now I can add whatever knob I want.
I'm also thinking I can use the open space in front of the knob, even in two high, now that it's bent up and shorter, for switches or something.
- Took the shifter out. (Remove the front half of the center consol, two bolts, remove pin and push out spring.
- Cut the rubber section off, and remove gear pattern insert.
- Place in vise, and tighten vise to take out as much bend as you want.
- Cut flat end off shifter
- Thread shifter
- Re-install.
- put gear pattern on left side of consol. (glue, velcro, whatever)
I had a broken screwdriver handle I tapped and stuck on there for now. I like the feel of it, but want 3-4 inches from the splined end of an axle for a knob.
2 hi
4 hi
4 low
...Don't follow Chili Palmer into the trees...
BluesMan is offline   Reply With Quote
Old 04-30-2007, 09:26 PM   #2
Dogman
Nice
Dogman is offline   Reply With Quote
Old 04-30-2007, 09:35 PM   #3
CheapJeep888
wow that cleared up a nice chunk of room, to bad i got the tuffy and its forever going to be in the same set up. Great idea though
"when in doubt, drive over it"
Under 21 Club [B]#1[/B]
CheapJeep888 is offline   Reply With Quote
Old 04-30-2007, 09:46 PM   #4
mud n rox
Buzzin' Half Dozen !!!
mud n rox's Avatar
That's pretty cool.
2001 TJ - With a little lift, some armor, four mud tires, and a few decals.
Caution: Rock and a hard place just ahead.
mud n rox is offline   Reply With Quote
Old 04-30-2007, 09:46 PM   #5
Dogman
I think a rock knob would be cool.
Old 05-01-2007, 03:48 PM   #6
BluesMan
I like the look of the rock knob. However I would like to pick my own rock.
I wonder what it would take to drill a hole in a rock? maybe a masonary bit?
Then epoxy in a correctly threaded nut?
There's a lot of cool river rocks in the dry canyons and such where we wheel.
Glock Forum
