Quantcast T-case Shifter Bracket upgrade w/ T-case drop and body lift - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > T-case Shifter Bracket upgrade w/ T-case drop and body lift
Old 04-05-2009, 04:17 PM   #1
04<TJ>renegade
Ok so i did a lil searching and i couldn't quite come up with an answer on this...I have a t-case drop and a 1.5" body lift on my 04 TJ and i'm wondering if this would work good on a setup like this. I made a bracket for the body bracket to lower everything and it lines up good but the dang t-case won't stay in 4 lo for anything. I'm not sure what is causing this but one of the t-case brackets look like a good option but i'm just conserned about the shifter length and if it'll reach that far. With the t-case drop and the BL i'm looking at a 3" variation from stock would this be a good up grade or is there a better solution.
O|||||||O
ONLY In My Jeep!!
04 TJ Renegade Edition: 35x12.50 KM2s 4" rough country 1.5" custom body lift 8.8 lsd RR SYE Safari Snorkel 01 Sahara seats hurst shift knob warn front bumper with m6000 and mini stinger custom rear bumper with tire swing muffler delete etc.
04<TJ>renegade is offline   Reply With Quote
Old 04-05-2009, 06:08 PM   #2
04<TJ>renegade
I investigated the issue more and after about an hour i realized the issue was in side the jeep not underneath...the z-box bracket that retains the shifter was denying the shifter from goin backwards...a couple hits with the cutting wheel and a couple hit with a hammer and it was notched out and works like a pro.
O|||||||O
ONLY In My Jeep!!
Glock Forum
