Quantcast T-Case shifter bracket? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > T-Case shifter bracket?
Old 05-09-2005, 12:14 PM   #1
ixl4
Anyone have detailed instructions with pics on installation of the transfer case bracket that comes with most body lifts?
Thanks.
ixl4 is offline   Reply With Quote
Old 05-09-2005, 12:18 PM   #2
crgrissom
Master of Reality
crgrissom's Avatar
Good pictures and discussion here:
http://www.4x4xplor.com/bl.html
Chuck
Chuck Grissom
Black Jeep Society Member
My Jeep
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline   Reply With Quote
Old 05-09-2005, 12:52 PM   #3
ixl4
I don't understand exactly what this bracket does... is it to better change transmission gears or only to better switch between 2 and 4hi/lo?
Will this bring back my gear shifter back to original position? (now after 1"mml it is further back, so 2/4/R are way lower back then they were before).
Old 05-09-2005, 12:56 PM   #4
Steps
It helps line everything back up on the transfer case shifter.
My Suspension lift did not come with one but after installing the TC drop kit I could not get it into 4lo so I made my own and it ligned everything back up the same as stock. I would suggest installing one if you have it or not.
GL!
Will
95 YJ
Steps is offline   Reply With Quote
Glock Forum
