T-case rear outpust shaft snap ring - JeepForum.com
post #1 of 10 Old 03-07-2013, 01:30 PM Thread Starter
MLaborde
T-case rear output shaft snap ring
I am in the middle of replacing my NP231J rear output shaft seal. I got the seal back on but the snap ring that goes against the seal is as far back as I can get it but has not yet found the groove & will not lock.
As this is my only vehicle & I have to go to work in several hours, I am kinda screwed unless I get this handled.
I sure would appreciate ideas.
1998 TJ Sport 4.0L
MLaborde is offline
post #2 of 10 Old 03-07-2013, 01:41 PM
cmecha
this might not help but i don't remember a snap ring being on the out side of the seal
edit to say the lock ring should be up against the bearing not the seal
please correct me if i'm wrong as this is important to know
"always upgraded, never replaced."
cmecha is offline
post #3 of 10 Old 03-07-2013, 01:56 PM Thread Starter
MLaborde
There is a lock ring behind the seal also. It is in front of the bearing. I had to get this ring off to get the old seal off. The FSM shows this ring & discusses getting it off but doesn't mention anything about on the installation.
MLaborde is offline
post #4 of 10 Old 03-07-2013, 02:04 PM
cmecha
aww i never rebuilt the np231 back to stock. may just need to seat the seal better.
cmecha is offline
post #5 of 10 Old 03-07-2013, 02:05 PM
todd8888
Have you tried to pull out on the shaft to see if it pushed in a little? Just a thought.
todd8888 is offline
post #6 of 10 Old 03-07-2013, 02:28 PM Thread Starter
MLaborde
It won't slide.
Well, it looks like I've gone & screwed it up. I lightly tapped & tapped with a screwdriver & hammer until I got it where I thought it was seated. I guess I tore the seal. I started it up & revved it some & now it's leaking worse than with the old seal.
Is this darn ring even necessary since the FSM doesn't mention putting it back on?
MLaborde is offline
post #7 of 10 Old 03-07-2013, 02:53 PM
dayriesw
dayriesw's Avatar
1987 MJ Comanche
I have done this recently on a t case I sold off. What todd said is right, there is a little play.... very little. You have to be gentle. At least you get another try
16 Taco
87 MJ Chief in pieces
dayriesw is offline
post #8 of 10 Old 03-07-2013, 03:05 PM Thread Starter
MLaborde
On my way to get another one now. Gotta drive 30 mins each way so if anyone else has ideas, my day is not done yet & I'm still looking for help.
MLaborde is offline
post #9 of 10 Old 03-07-2013, 03:23 PM Thread Starter
MLaborde
BTW, how did you get the ring back on?
MLaborde is offline
post #10 of 10 Old 03-07-2013, 06:51 PM Thread Starter
MLaborde
Got the new one, got it on, put the snap ring on with a new set of snap ring pliers I bought. Started it up & when I got underneath, the ring was spinning. I shut it down & popped the ring once more & watched it seat perfectly. But the damage was done already. It's leaking badly.
While spinning, the ring had sheared off a TINY TINY sliver of the rubber part of the seal. It was such a tiny piece that I can't imagine that it matters.
I guess I get to take it to a shop and let it sit over the weekend. I'm already $84 in the hole...
I'd try once more if I thought I had a foolproof method. I'm getting pretty quick at this.
MLaborde is offline
