Symptoms of messed up Throw out Bearing or bad clutch?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Symptoms of messed up Throw out Bearing or bad clutch??
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNorthridge4x4 - Free ARB Air Compressor with Locker PurchaBds fox ipf 2.0 racing series shocks now available at rock
Unread 12-16-2007, 12:12 AM   #1
rubicon4x4
What are some symptoms of a broken/damaged throwout bearing? I have a metal clanking sound after I shift sometimes and it is erraticly coupled with the engine revving but no acceleration until the metal sound like something sliding into place or sliding free of a bind occurs. Could this be a bad throwout bearing or some other clutch part or might it be a bad throttle positioning sensor? Maybe even the transfer case and/or linkage?
What is my best course of action besides just taking it in to the shop?
2004 Black Wrangler SE 4cyl manual.
"Now, we must all fear evil men, but there is another kind of evil, which we must fear most, and that is, the indifference of good men."
rubicon4x4 is offline   Reply With Quote
Unread 12-16-2007, 12:14 AM   #2
McLovin
seems like I remember something like that happening when the fingers on the clutch presure plate break. Not 100% sure though
http://jeep4playoffroad.org/index.php --your local oregon coast club
McLovin is offline   Reply With Quote
Unread 12-16-2007, 12:18 AM   #3
o2tj
o2tj's Avatar
sounds like the rear diff to me? could b the syncro on the first gear cluster.
o2tj is offline   Reply With Quote
Unread 12-16-2007, 12:35 AM   #4
97tjtom
how does the noise change when you simply rest your foot on the clutch pedal? if the noise changes and you only moved the pedal 1/4 of an inch, its probably the throwout bearing.
if youre saying the clutch engages after something slides into place, maybe the bearing is completely shot and is binding on the transmission input shaft.
seems like either way whether its the bearing or the fingers, youll have to pull the tranny to fix it. get quotes on a clutch and throwout bearing then pull the tranny and see whats up. then go get the part you need.
it may also be the synchros in your tranny. how many miles?
Current: 1999 TJ 4.0 5 Speed
Past: 1999 XJ 4.0 Auto, 1993 XJ 4.0 5 Speed, 1997 TJ 4.0 5 Speed, 1994 XJ 4.0 5 Speed, 1993 Cadillac Sedan Deville 4.9L V8, 1991 Isuzu TrooperII 2.8L 5 Speed
97tjtom is offline   Reply With Quote
Unread 12-16-2007, 12:50 AM   #5
rubicon4x4
46k miles, it's an 04 manual 5 speed. i taught myself how to drive stick in it at 34k miles (when i got it) so take that into consideration.
I had a 45k mile checkup drained and filled both diffs and antifreeze/oil change and they didn't say anything was wrong with the diffs.
Also it does idle kind of inconsistently when I first start it up and it is sometimes tricky getting it into first gear (thought that just might be the colder weather though 35*)
