SYE Questions - JeepForum.com
post #1 of 4 Old 06-29-2010, 01:31 AM Thread Starter
kuruma
SYE Questions
OK Need pointed in the right direction on this one. Here's my issue:
I am currently running a Rancho lift in an undetermined height (just bought the jeep and haven't measured) I believe it is a 2-4 inch lift. Whoever installed it didn't do an SYE kit and I have spacers under my belly skid which limits my BOA. I'm going to be going with a more complete OME hybrid kit from DPG in the future and the lift will be different. From what I have read I think it would be better to just run this one as is for now and wait until I get the lift I want on it until I go for a SYE kit. Is this correct? I don't want to spend the cash for a kit then have to spend more money if the next one is of a different height. I'd like to plan it all out so it can all go in at the same time without having to go back in and install stuff over a longer period of time to get it correct. I've done a few searches on here and have read quite a bit but I just want to make sure what is in my head is correct so I can make the purchase and install as seamless as possible. Measure twice, cut once principle. Any guidance would be greatly appreciated.
kuruma is offline
post #2 of 4 Old 06-29-2010, 12:24 PM
Speed94
I just ordered my kit from DPG. He didnt mention anything about needing to do the SYE with that kit. I got the brown dog mml though. I will most likely be doing a SYE when I do my TT though
97 TJ PD club member #007
Speed94 is offline
post #3 of 4 Old 06-29-2010, 01:21 PM
Benderff
Benderff's Avatar
What do the control arms look like on your lift? Rancho makes a 2.5" kit and a cheaper 4'' kit. If your OME kit is going to be 2.5" I wouldn't worry about it, and just get the SYE now. If you have a 4" kit I would still do it now, since it's cheap to have the shaft cut shorter if you needed. Running a SYE and a CV shaft is a huge upgrade.
Benderff is offline
post #4 of 4 Old 06-30-2010, 12:25 AM Thread Starter
kuruma
OK Thanks guys. I'll look into pricing these then and see what I can do.
kuruma is offline
sye , slip yoke eliminator
Here's some questions for ya. Bigboyky YJ Wrangler Technical Forum 4 02-09-2009 12:30 AM
questions about an 87 asbury YJ Wrangler Technical Forum 0 02-01-2009 09:32 PM
2 Questions about OME.. RVA_TJ06 Wrangler General Discussion 1 01-24-2009 11:09 PM
Questions... lifetrecker TJ Wrangler Technical Forum 9 11-07-2005 10:57 PM
2 lug nut questions- Mickey Mouse kind of questions kaybone TJ Wrangler Technical Forum 2 05-04-2005 05:34 PM
