SYE Question - JeepForum.com
post #1 of 10 Old 07-07-2010, 07:38 PM Thread Starter
phillies4752
phillies4752's Avatar
SYE Question
Hey, I have came across a SYE rough country kit thats going for $125 and was wondering.... Do I have to have both a SYE and a CV drive shaft all at once? Or can I wait a bit to get the CV drive shaft.
Right now I have a 2inch BB with a 1.25inch BL and a 1inch MML. I eventually want to work my way up to a 4inch suspension lift. Just wondering if I can do it in stages.... im still in college and money is tight
Thanks for your help
phillies4752 is offline
post #2 of 10 Old 07-07-2010, 07:47 PM
dcope17
Something has to adjust the driveshaft length to compensate for suspension moving up and down. If you remove your slip yoke... you need a driveshaft that will expand and contract. ( I'm sure there is a specific name for it but I don't know what it is )
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
post #3 of 10 Old 07-07-2010, 07:55 PM Thread Starter
phillies4752
so im guessing i can't do anything until I have a CV driveshaft? Or do I have to have all three... SYE, CV, and lift kit?
post #4 of 10 Old 07-07-2010, 08:06 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
well considering the driveshaft you have now uses a slip yoke, and the SYE is called a Slip Yoke Eliminator, no.
you don't need to buy the CV shaft at the same time as the SYE, you just can't use a rear driveshaft. you'll have to drive around in front wheel drive (4x4)...which won't hurt anything.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #5 of 10 Old 07-07-2010, 08:11 PM Thread Starter
phillies4752
I just can't go over 55 right? haha, im thinking about holding off till I have the CV driveshaft. Would the SYE and CV driveshaft work with my 2 inch BB and 1.25 BL for a bit until I get a lift kit?
post #6 of 10 Old 07-07-2010, 08:13 PM
durango-bob
2006 WK
As was said, you could just leave the rear DS off. But ideally you do the SYE, new DS and the lift at the same time. The new DS is typically longer to compensate for the lift, so you at least have to do the lift and DS at the same time if you use the front wheel drive option.
durango-bob is offline
post #7 of 10 Old 07-07-2010, 08:21 PM Thread Starter
phillies4752
alright, thank you for your help! that clears up a lot of stuff. I guess there will be a lot of parts sitting in my shop for some time haha but ill get there someday! thanks JP!
post #8 of 10 Old 07-08-2010, 08:23 AM
mrbates
RESIDENT METAL
you also need adjustable upper control arms in the rear to reset your pinion angle
I have a Jeep.
2003 X. 3" SA. Locked D44s F/R. 35" MTR-K's
mrbates is offline
post #9 of 10 Old 07-08-2010, 08:46 AM
MO2500
x2
CV driveshaft and SYE will do nothing for you if it's not setup correctly (pinion angle same as the driveshaft angle)
Instagram: @omsmike
MO2500 is offline
post #10 of 10 Old 07-08-2010, 08:53 AM
Unlimited04
don't forget you can pull the front CV shaft from any junkyard XJ or TJ and have a local driveline shop modify it to fit...typically less than $100.
Useful Write-Ups:
Funny:
sye kit
Lift/Tires question and Cleaning soft top & engine question Bryan_16 TJ Wrangler Technical Forum 16 05-19-2012 03:25 PM
Front sway bar question + bonus disco question WranglerTom TJ Wrangler Technical Forum 7 12-02-2011 08:13 AM
1988 carberator question and wiring (general) question prljeep YJ Wrangler Technical Forum 15 05-08-2009 11:50 AM
quick connecting rod question and tourqe wrench question???? johnrezz YJ Wrangler Technical Forum 2 10-18-2008 07:20 PM
Tire question(noob question but just a quick answer needed) 07SilverX JK Wrangler Technical Forum 3 12-25-2007 03:35 PM
