SYE kit for Rubicon? - JeepForum.com
post #1 of 12 Old 07-18-2010, 10:10 PM Thread Starter
jhf56
I am getting the 3.5" standard Rubicon Express lift kit and i was wondering if i have to do a SYE kit. I heard that since i have a Rubicon i dont have to, i dont want to have any vibrations.
jhf56 is offline
post #2 of 12 Old 07-18-2010, 10:11 PM
red88MJ
the rubi already has a fixed yoke on the 241 tcase so no you dont need a sye
This must be a low range beer because it makes everything slower...
MY LJ BUILD...
red88MJ is offline
post #3 of 12 Old 07-18-2010, 10:13 PM
BriansCJ
1994 XJ Cherokee
Rubis have a fixed yoke so no "Slip Yoke Eliminator".
I bought a 4" lift for our Rubicon and used a 1" T-case drop. You should be fine with the drop.
If you dont want to put the t-case spacer in, be prepared to buy a new rear driveshaft, just in case.
Where in NJ are you?
- Daily Driver & Weekend Wheeler
- Slow
BriansCJ is offline
post #4 of 12 Old 07-18-2010, 10:16 PM
242TJ
It is possible to get vibrations and wear out u-joints with a Rubicon. Even though it has a fixed yoke, the stock shaft is not a double cardan. Only a problem with massive lifts though. With a 3.5" lift I don't think you will have any problems.
ll,ll,
lL_l--OlllllllO-
)_)-()_)--)_)
242TJ is offline
post #5 of 12 Old 07-18-2010, 10:24 PM Thread Starter
jhf56
Im in Paramus, any recomendations of which t-case drop kit to get?
jhf56 is offline
post #6 of 12 Old 07-18-2010, 10:29 PM
ROLLTIDEtj
As answered above, no, no sye. You will likely have vibs with the 3.5" kit (closer to 4-4.5"). Don't waste your money on a t-case drop kit. Just use washers and the appropriate length bolts will the vibs go away. That way you aren't dropping it any more than necessary.
2004 Rubicon - 4.0 - 5 speed manual - Rough Country 4" Stage II lift, RC front adjustable track bar, 2.2 shocks, 33x12.5x15 Goodyear MTR with Kevlar on Crager soft 8's, 4 Hella Black Magics, Edge Trail Jammer with Intake, JL TR 2-ways in the pods, Kenwood Excelon deck in the dash, Rough Country Stinger & Winch Plate, Trail Gear rear bumper w/ tire carrier, HiLift, Rock Krawler X Factor Plus Steering
ROLLTIDEtj is offline
post #7 of 12 Old 07-19-2010, 02:32 AM
RogueSpear2023
As others have said you don't need a SYE, but you may want to look into a CV drive shaft, like one from Tom Wood, that is made for the Rubicon 1330 u-joints to avoid any vibrations. And yes you can get vibrations with a 3.5" lift, even from shorter lifts in fact. If you got a CV drive shaft, then you would not need a t-case drop.
Max
2003 Jeep Wrangler Rubicon
4.0L, 42RLE, Dual Tops, Full Doors, JKS Front Disconnects, Cragar Soft 8 Black Wheels, 33x12.5x15 Goodyear Duratracs, .75" Front Coil Spacers, Bushwacker 6" Flat Fender Flares, Skid Row Steering Box Skid, LubeLockers, Rubicon Locker Mod, OBA, Cobra 19 Ultra III CB, 3' Firestik, Rough Country 2.2 Steering Stabilizer, RC 1.25" BL, RC 1" MML, RC Grab Handles, Fog Lamp Bent Pin Mod, 4" Apline S Series Speakers, Kenwood Excelon 6.5" Speakers, 6.5" JL Audio 6W3V3 Subwoofer (in center console) w/MTX Thunder 202 amp, IPF H4 Headlight Housing, Sliverstar H4 bulbs.
"Buying a jeep and not taking it off road, is like buying a dragster and never taking it to the track"
RogueSpear2023 is offline
post #8 of 12 Old 07-19-2010, 06:45 AM
Zen
Your RE kit should come with a T-case drop kit. My SF kit did, but I didn't use it. I think I still have it lying around.
-Darkstar, judy-judy. I'm going in for guns.
-Stick, splash one!
Zen is offline
post #9 of 12 Old 07-19-2010, 11:01 AM Thread Starter
jhf56
how bad do u guys think the vibs will be, because a cv drive shaft is pretty expensive, and i dont have the extra money for that.
jhf56 is offline
post #10 of 12 Old 07-19-2010, 11:24 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
then don't lift the Jeep. its not a matter of "how bad" the vibes will be...any driveline vibes are bad and destroy the u-joints, bearings, seals, etc.
read: http://www.jeepforum.com/forum/f9/wh...nt-one-854790/
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #11 of 12 Old 07-19-2010, 11:27 AM
Imped
Imped's Avatar
Exactly. ANY vibe is bad and will destroy parts faster than you can replace them. I can guarantee that the double cardan shaft (and adj. control arms needed to adjust pinion angle) will be cheaper in the long run than running around for a year with minor vibes.
OlllllllO
IndyORV
Imped is offline
post #12 of 12 Old 07-19-2010, 12:42 PM
dcope17
Option 2.) Lift the Jeep, remove the rear driveshaft then put it in 4HI. Now you have a lifted front wheel drive...
Life with Christ can be explained like a Jeep...
Being in the Word... grows your tire size.
Prayer... gains more ground clearance.
Fellowship... Is like having a good spotter.
The more of these you have... the easier it is to get over obstacles in your path.
dcope17 is offline
sye , kit , rubicon
Rubicon TJ vs. Sahara TJ -- Rubicon owners chime in! retromag123 TJ Wrangler Technical Forum 44 12-11-2009 07:18 AM
2003 -2006 Rubicon or post 2007 Rubicon WhatBump1 Wrangler General Discussion 5 06-08-2009 08:56 PM
Better performance offroad- jk rubicon vs. 4 door unlimited rubicon David Hinton JK Wrangler Technical Forum 6 07-20-2006 10:07 AM
Jeeb Rubicon or Jeep Rubicon Unlimited? Indefatigable TJ Wrangler Technical Forum 11 07-03-2005 04:49 AM
Dealer said the Rubicon is all u need 4 rubicon trail SMOKE Dog TJ Wrangler Technical Forum 41 03-24-2005 08:56 AM
