sye kit and ford 8.8 - JeepForum.com
post #1 of 6 Old 08-26-2010, 07:36 PM Thread Starter
sburton1
Hey guys real quick question im getting ready to buy a advanced adapters sye kit and Tom woods drive shaft combo, with some currie jj control arms. my questions is that if I eventually get a ford 8.8 rear end from ecgs will I still be able to use that tom woods drive shaft with the adapter for the ford 8.8 or would I need a different drive shaft? Id like to only buy that drive shaft once if you feel me.....
sburton1 is offline
post #2 of 6 Old 08-26-2010, 07:51 PM
bmxrules39
The Ford Explorer 8.8-Inch Rear Axles
looks like the pinion length is really close to that of the 35
and the pinion height is the same so I'd say you'll be fine
You should fill out your profile more ie~what axles you have
wHitt
bmxrules39 is offline
post #3 of 6 Old 08-26-2010, 08:08 PM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
Let TW know what you plan on doing and they can make a DS that will work for both. Your drive shaft will need to be a little shorter with the 8.8. They have a HD DS that has more extension and then it can compress enough for your application.
SAVVY OFF ROAD - Winner of the King of the Hammers Everyman Challenge FIVE years in a row!
Email me for the fastest response:
Like us on Facebook
The ONLY place to get Savvy/Currie Lifts and parts! The best price and support!
Now with Lifetime Guarantee
2003 TJ Project Unrolled
Savvy is offline
post #4 of 6 Old 08-27-2010, 08:47 AM Thread Starter
sburton1
Thanks guys I just dont want to waste any $$$$ and do it right the first time, like I havent done in the past;(
sburton1 is offline
post #5 of 6 Old 08-27-2010, 10:44 AM
pwcracer
This isn't the case for everyone, but when I switched to the 8.8 my cv driveshaft is almost too short. It is at the end of the splines. I now wish I would have measured and ordered it after I installed the 8.8
pwcracer is offline
post #6 of 6 Old 08-27-2010, 11:05 AM
Savvy
Vendor
Savvy's Avatar
2014 JK Wrangler
TW make two different type of drive shafts. One like the OEM and the other X spline which gives you much more compression and length. Cost just a tad more but well worth it. An added benefit in the X spline is that it is a lot beefier.
Like us on Facebook
Savvy is offline
which axle?? Ford 8.8 or Ford 9" tcoche TJ Wrangler Technical Forum 31 07-20-2010 12:31 AM
Help With Ford 9", or Ford 8.8 Cbaughn YJ Wrangler Technical Forum 10 10-29-2008 06:39 PM
Ford SVO disk brake kit on Ford 8.8 texashoghunter TJ Wrangler Technical Forum 0 07-10-2008 08:12 PM
Ford 10.25 vs Ford 9" Allen52105 YJ Wrangler Technical Forum 1 07-24-2007 07:45 PM
Ford T18 and Ford Dana 20 JOKER4INK YJ Wrangler Technical Forum 0 11-23-2005 06:00 PM
