SYE installed at 3"lift, now 4" lift= vibes?? - JeepForum.com
post #1 of 9 Old 07-25-2008, 02:47 AM Thread Starter
JackMJeep
JackMJeep's Avatar
To make a long story short, I had an SYE kit installed when I had a 3" lift installed, now that I have moved to a 4" lift kit, I'm feeling drivline vibrations. Is there an adjustment that needs to be made or something? I appreciate any help you all could give me. Thanks.
JackMJeep is offline
post #2 of 9 Old 07-25-2008, 03:02 AM
Rafikie
did you re-adjust the angle of the rear axle to point toward the TC?
2000 TJ WW build in progress
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #3 of 9 Old 07-25-2008, 03:14 AM Thread Starter
JackMJeep
JackMJeep's Avatar
I don't know becuase I had an offroad shop install the lift for me. How can I check to see if the angle of the rear axle is pointing toward the TC?
post #4 of 9 Old 07-25-2008, 03:49 AM
Rafikie
Take a look at the rear yoke, it should be pointed at the yoke on the TC
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #5 of 9 Old 07-25-2008, 07:37 AM
Trombino
Trombino's Avatar
1978 CJ7
If you are going from truly 3" to truly 4", the driveshaft you bought when you did the 3" lift should still work, so you should be able to correct by adjusting the upper control arms. Just out of curiosity, did you drive without the SYE when you did the 3" lift, or did you do at the same time?
'78 CJ7 -- Chevy 350 SBC, Holley 4-BBL, TH700R4, B&M Performance Shifter, Dana 300 w/ Twin Sticks, 3" Shackle Lift, 3" Body Lift, D30 Front (Disc), AMC 20 Rear w/ Moser 1-Piece, 4.10's, 35x12.50/15 General Grabber MT's, Cragar Soft 8's (15x8 w/ 4" BS)
Trombino is offline
post #6 of 9 Old 07-25-2008, 07:42 AM
otisdog
2008 WK
You need upper rear adjustable control arms to make the adjustment.
Jim
08 Grand Cherokee Overland
otisdog is offline
post #7 of 9 Old 07-25-2008, 09:33 AM Thread Starter
JackMJeep
JackMJeep's Avatar
Just crawled under the Jeep and saw what your talking about. It doesn't look to hard to install. Will it be easy to make the adjustements, and do you have any suggestions on making them?? Thanks for your help.
post #8 of 9 Old 07-25-2008, 10:42 AM
Rafikie
Like otis said you'll need adjustable control arms first. If you have them already (in most cases) you just have to unbolt 1 end and give it a few spins to lengthen the arm. Pay attention to how many turns you do and do the same amount to the other side. Once everything is lined up better tighten the jam nut again and give it a shot.
RIP: 97 TJ juggy
WM4x4
Rafikie is offline
post #9 of 9 Old 07-25-2008, 12:18 PM
otisdog
2008 WK
Yea you can put a jack under the front of the diff than remove one end of the upper control arms. Jack the front of the pinion up until it's lined up then adjust your control arms and put them back on.
Jim
otisdog is offline
Has anyone installed the "Full-Traction 2" Econo Lift" kurtfriedrich JK Wrangler Technical Forum 0 08-31-2008 02:10 PM
go'n from 2" to 4" lift, no vibes now... Libtekguy TJ Wrangler Technical Forum 3 06-17-2007 12:51 PM
Dealer installed 3" lift and 33" tires wetsu TJ Wrangler Technical Forum 5 03-06-2004 09:10 AM
Dealer installed 3" lift and 33" tires wetsu YJ Wrangler Technical Forum 3 03-05-2004 05:11 PM
lift installed and flat fendered."pics" B-Ray YJ Wrangler Technical Forum 5 12-23-2003 08:00 PM
