switch panel - JeepForum.com
post #1 of 3 Old 03-15-2007, 01:10 PM Thread Starter
hillbillybob
switch panel
on a 03 tj how does the switch panel, the stock location come off, can I just pull it out, or does the dash have to be disassembled ?.
hillbillybob is offline
post #2 of 3 Old 03-15-2007, 01:26 PM
PhulesAu
Probably have to pull dash facing off, 04's are that way. then it's a seperate pod mounted to the dash frame, 2 - 3 screws.
PhulesAu is offline
post #3 of 3 Old 03-15-2007, 02:09 PM
Geeps
Yes, you have to remove the instrument bezel (the cover) to get to the screws that hold the switch pod. Should be 2 screws on top of the dash, one behind the ash tray (at least there is on a 2000TJ).
Geeps is offline
want to change fog light panel switch with 4 wires to rocker switch with 3 terminals lomondpeak TJ Wrangler Technical Forum 6 11-28-2009 09:21 PM
switch panel ARCHERYNGUNS JK Wrangler Technical Forum 30 04-15-2009 02:55 PM
ARB switch panel - NEW! Stu Olson TJ Wrangler Technical Forum 10 02-16-2008 04:04 PM
Switch Panel Jerry All-Bran TJ Wrangler Technical Forum 24 11-04-2005 10:55 PM
how does the switch panel come off? wingman TJ Wrangler Technical Forum 3 11-23-2003 03:37 PM
