Quantcast Swing away TC install question. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Swing away TC install question.
Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at BasIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Old 06-29-2006, 07:55 AM   #1
Mr. Tarmac
Couple of tire carrier questions.
1 - when you remove the stock spare tire mount and brake light from the tail gate to install a swing away carrier, what do you do with the empty bolt holes where the stock carrier mounted?
2 - if you choose not to re-route a new 3rd brake light, what do you do with that wiring and hole where it comes out of the tail gate?
Do you just leave the holes open? Wouldn't that allow water to leak in?
Mr. Tarmac is offline   Reply With Quote
Old 06-29-2006, 09:09 AM   #2
NoUse328
I put bolts in all holes except where the tail light wire went.
For extra protection, I put an extremely thin layer of rtv on the bolt heads and threads, but I'm paranoid about rust ever since I took off my tire carrier.
NoUse328 is offline   Reply With Quote
Old 06-30-2006, 07:34 AM   #3
Mr. Tarmac
So, what about the tail light wire hole?
Old 06-30-2006, 07:38 AM   #4
NoUse328
I just left it open. Then I used it for my CB wires.
Old 06-30-2006, 07:45 AM   #5
Max1775
I left the grommet in the hole and just stuck a screw in the hole in the grommet although I don't think it'd really be an issue.
05' Rubicon Unlimited, 33" BFG M/T's
[CENTER][SIZE="5"][COLOR="DarkRed"]SAW 'EM OFF![/COLOR][/SIZE][/CENTER]
Max1775 is offline   Reply With Quote
Old 06-30-2006, 08:12 AM   #6
jcd
I've still got the wire for the brake light coming through the grommet, though it's just coiled up and taped to outside of the tailgate... eventually I may actually get off my butt and a third brake light installed
2008 Jeep Sahara Unlimited
Terraflex 4" 35's 5.13
jcd is offline   Reply With Quote
Old 06-30-2006, 08:16 AM   #7
Rocky529
Jeep
Rocky529's Avatar
1. I put the bolts back into the tailgate from where the old stock tire carrier came out... you can't even see them anyway when the swingaway is closed and the tire is mounted.
2. I just unplugged it from behind the plastic cover in the tailgate, and pulled it through the hole in the tailgate. I then put clear silicone over the hole.
2004 Jeep Wrangler Sport - 5 speed
Silver Metallic finish with black dual tops - Dana 44 Rear
2.25" Suspension Lift with Old Man Emu Shocks
Performance Accessories 1" Body Lift
Daystar 1" Motor Mount Lift
Spidertrax 1.25" Wheel Spacers - 32"x11.5" MT/R Tires
Rocky529 is offline   Reply With Quote
Glock Forum
