Sweet Coolant Smell but No Coolant Leak? - JeepForum.com
post #1 of 5 Old 11-06-2010, 11:22 PM Thread Starter
JB73
So as some know, I have basically had a major once over on my 2.5L. The newly replaced head, new thermostat, new hoses, new temp sensor, new radiator & cap & the new water pump replaced 11 mnths ago.
The majority of the wrok has been done over the last couple months. I notice a sweet coolant smell when i get out of my Jeep. The overflow coolant container isnt loosing coolant and I cant see any leaks anywhere. I thought it may have been just coming from the coolant bottle due the the yellow flip lid that doesnt really seal tight when snapped on. I took a balloon and stretched over the fill and snapped the yellow did over that.....fit tight then. I then took some very dense spunge foam and put a piece in the overflow channel to maybe help keep smell contained. I still smell the coolant. Any ideas ......
Also they did a pressure test on the motor when they found the cracked head which was replaced. I dont smell it coming from the exhaust either. Definitely coming from under hood area / not inside the jeep.
JB73 is offline
post #2 of 5 Old 11-07-2010, 01:01 PM
yv4me
It always seems to take a long time for the smell to leave after any anti freeze spill. With the top off, I can sometimes smell just a whiff when the thermostat first opens. Maybe from the pressure forcing the vapor thru the coolant recovery bottle? As long as there are no leaks, it will go away in time.
Expediency is no excuse for substandard work!
yv4me is offline
post #3 of 5 Old 11-07-2010, 03:12 PM
brkeep
I blew the plastic cap off my radiator. After replacing the entire cooling system it took several weeks for the smell to go away.
brkeep is offline
post #4 of 5 Old 11-07-2010, 03:35 PM
wushaw
Rockin jeep
wushaw's Avatar
Give it time to either burn off or to show its head. Keep watching for stains on and around radiator, not drips but stains & smears.
wushaw is offline
post #5 of 5 Old 11-07-2010, 11:56 PM Thread Starter
JB73
Thanks for the advice. I did use engine bright degreaser to wash the engine bay down , hoping that would do it but no. Ill keep an eye on it.
JB73 is offline
I see coolant I smell Coolant But can't find leak. MrB TJ Wrangler Technical Forum 23 07-18-2010 07:33 PM
Antifreeze/Coolant Smell but no leak... greta TJ Wrangler Technical Forum 8 04-28-2010 05:28 PM
huge coolant leak/ creamy coolant?? 11Bgixx TJ Wrangler Technical Forum 17 01-11-2010 10:24 AM
Coolant Smell ryobi TJ Wrangler Technical Forum 7 02-26-2007 01:05 PM
smell coolant... Mr. Frogington TJ Wrangler Technical Forum 8 09-11-2003 05:37 PM
