Quantcast SwayLOC....a discussion. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > SwayLOC....a discussion.
Rough Country Deals at JeepHut.comIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed LineFREE shipping on Rugged Ridge Soft tops @thejeephut.com
Old 04-15-2008, 01:38 PM   #1
tcmault
You know you want to show off your toys. Please post up pics of your swayloc. Especially the manual dual rate version. Do they come painted black now or are the ones that I have seen black been painted by the customer?
Are there any known issues with the latest generation?
Where is the cheapest place to purchase the manual Dual rate system? Any discounts for buying two of them?
tcmault is offline   Reply With Quote
Old 04-15-2008, 01:52 PM   #2
V-8unlimited
maybe a discount for 3 of them? LOL, I am also to the point of ordering one for my ride.
V-8unlimited is offline   Reply With Quote
Old 04-15-2008, 04:00 PM   #3
VinoTJ
Manual Dual Rate
Here are some pics (note: I moved my end links to the inside after getting some tire rub with my tire/wheel combo - Swayloc is one of my favorite mods!!!!!!)
I got my from Northridge4x4 $499.95 (free shipping).
2008 Wrangler Unlimited X
VinoTJ is offline   Reply With Quote
Old 04-17-2008, 03:44 PM   #4
lupinsea
I've also greatly enjoyed my SwayLOC. It was a superb upgrade from the Anti-rock, which itself was a superb swaybar system to run on the trail. The SwayLOC has all the off-road flexyness of the Anti-rock but with slightly stiffer on-road handling than a stock OEM swaybar. Like Vino this is one of my favorite mods.
I bought mine from Northridge, too. $499. Back when I was looking there didn't seem to be any price difference from place to place. And I think that is still the case. Still, it's worth the money.
The colors of the SwayLOC are as it is from ORO. No painting by me. The arms are black and the aluminum bits are annodized gray.
There are zero issues I've had with mine. It's a 2nd generation one and incorporated improvements the designer and manufacturer worked out between the first and second generations. Namely, some of the tolerances had been increased in the latch mechanism so that it cleans out easier and doesn't get jammed with dirt. Plus I think there were some changes made to the outer swaybar (thicker) which both stiffened it up and also made a snugger fit with the inner swaybar compared to the older set up.
Anyways, the versions sold now are great. No problems.
Some photos from the install process and trail use. . .
Photo of the two swaybars (torsion rods). The inner swaybar is for offroad trail use and
the outer swawybar is what is engaged for street use.
Close up of some of the hardware and parts. Top quality stuff. The upper-
right gray pieces are the machined aluminum engagement block and spring-
loaded flip-a-lever parts. The heim joints have a teflon race and are used in
the end links. The lower piece is the end of the fan-shaped plate with a
splined hole that clamps to the outer torsion rod.
Here's the driver's side arm with both smaller and larger splined holes for
the two torsion rods. Both rods clamp to this arm.
Slipping in the SwayLOC outer torsion rod and bushing.
The two torsion rods installed.
The finished SwayLOC.
SwayLOC in action.
Sorry, don't have as many flex shots as I used to. The SwayLOC works
beautifully, however.
- Jay
lupinsea is offline   Reply With Quote
Old 04-17-2008, 03:48 PM   #5
Jakemd98
Choosy moms choose jeep.
Jakemd98's Avatar
if you were to get the single rate swayloc and later down the road want the dual rate, could you up-grade it?
Jake Davis
97 Jeep Wrangler
4.0, 5 speed AX-15, D44 & Ford 8.8 w/Detroit - 4.88, NP-231, OME 2.5" coils w/1.25" spacers on front, 1.25" JKS BL, 35X12.50R15 KM2 on 15x8 Eagle alloys, Banks Header, Banks Monster Exhaust, Brown Dog MML, Rhino Liner, Tuffy Glove Box, AtoZ Rockers, Optima Red Top Battery.
1998 GMC Yukon
Wilmington weekly 4x4 meet
Jakemd98 is offline   Reply With Quote
Old 04-17-2008, 03:53 PM   #6
The Mean Fish
One of the guys in our club used his for the first time this weekend in Clayton OK and ended up with a broken end link. It looked to us like he didn't have enough thread inside the link, I haven't heard what ORO has told him about it. They sold him the length of links to match his lift height, we're wondering if maybe that was wrong.
Originally Posted by 84 CJ7 View Post
The Mean Fish you seem to hate big business and love big government. My guess is you are drinking the coolaid that Pelosie, Reid, Barny Frank, Biden, and Obama are serving.
The Mean Fish is offline   Reply With Quote
Old 04-17-2008, 03:56 PM   #7
The Mean Fish
Did they build a single rate? Isn't the dual rate option the entire point of the Swaylock otherwise it would be a $500 disconnect?
Old 04-17-2008, 04:23 PM   #8
Jakemd98
Jakemd98's Avatar
http://www.offroadonly.com/products/suspension/swaylocsr/index.shtml
the single rate is $375.
Jake Davis
97 Jeep Wrangler
1998 GMC Yukon
Old 04-17-2008, 04:26 PM   #9
The Mean Fish
That's pretty interesting...
Old 05-27-2008, 08:49 PM   #10
V-8unlimited
Contact info for northridge?
Old 05-27-2008, 09:07 PM   #11
Crashnburn80
Northridge4x4:
http://www.northridge4x4.com/
I purchased mine from Red Rock 4x4, another JF vendor:
http://www.redrock4x4.com/shop/index.php?main_page=product_info&manufacturers_id= 63&products_id=2564
OME ZJ/LJ combo | SwayLOC | 1.25" BL | Nth TT | Riddler diff covers | EMP gastank skid | 33" MTRs | Warn M8000 | Cobra75
and much more...
Riddler torture test video
Oil Filter Study
Useful Axle Info Thread
Crashnburn80 is offline   Reply With Quote
Old 05-27-2008, 10:04 PM   #12
JBWood05TJ
Cut to Fit-Paint to Match
JBWood05TJ's Avatar
You're right - it is basically a $375 disconnect. But on road, it is alittle firmer than the stock antisway bar.
We save dogs: http://www.secondchanceshepherds.org/
JBWood05TJ is offline   Reply With Quote
Old 05-27-2008, 10:08 PM   #13
JBWood05TJ
JBWood05TJ's Avatar
That would be me. I exchanged e-mails with Steve at ORO and he replaced my links no problem. Took care of it right away, too, I had the new links before the end of the next week. Very happy with the SwayLoc so far. Since I lost that link on Day 1 at Clayton, I'd like to get back up there or over to Katemcy Rocks to give it a good workout.
Old 05-27-2008, 10:21 PM   #14
msavard
LOVE my swayloc.... if you've got the scratch it's most definitely worth it.
2004 Yellow TJ Sport
(purchased stock on 6.3.06)
4.0L Auto • 35" Maxxis Bighorns • D30/D44 w 4.88 Gears • 2.5" OME LJ/XJ lift • JKS Trackbars • Brown Dog MML • 1" BL • Warn Engine Skid • Aussie Locker (FR) / Rubi Air Locker (REAR) • SYE/CV • Nth Adj Control Arms • Bestop Oversize Tire Carrier • PSC Rocker Knockers • ORO Swayloc • TNT Tube Fenders
MIDSOUTH JEEP CLUB > Jeepers from TN, AR, MS, and KY
msavard is offline   Reply With Quote
Old 05-27-2008, 11:09 PM   #15
rescueTJ
Couldn't be happier with my dual rate air actuated. After one short test run I really like the way the front and rear suspensions are working together again. Yesterday watching my buddy fight to reconnect his discos in the rain while I was dry in the cab was just icing on the cake.
http://www.cardomain.com/member_pages/show_image.pl?image=http://memimage.cardomain.com/member_images/10/web/2230000-2230999/2230789_22_full.jpg
rescueTJ is offline   Reply With Quote
Glock Forum
