Sway Bars and Track Bars - JeepForum.com
post #1 of 6 Old 07-11-2010, 08:13 AM Thread Starter
DivineKaos
Hey All
I'm new to the TJ world, coming from a YJ.
Can I ditch my track bars? How about my sway bars?
I did a bit of research and couldn't find much about this!
Thanks!
"A man has to know two things in life, limitations and priorities. You let your priorities get in the way of your limitations." - MrBlaine
DivineKaos is offline
post #2 of 6 Old 07-11-2010, 08:17 AM
biffgnar
biffgnar's Avatar
TJs with coil springs are different than your YJ with leaf springs. Without a trackbar in a TJ not much to keep your axle under the jeep laterally. Keep them. Swaybar less critical. Some remove although most keep them and either use disconnects for offroad or go to something like Anti-rock/Swayloc.
Romney in 2020!
biffgnar is offline
post #3 of 6 Old 07-11-2010, 08:20 AM Thread Starter
DivineKaos
Do I have front and rear trac bars? Sorry if this is a stupid question..trying to learn...
I was told to ditch the rear sway bars, and just disco the front when offroading...
I was told to get adjustable trac bars (yes plural- hence my first question about front and rear)..this a pretty solid move?
post #4 of 6 Old 07-11-2010, 08:26 AM
biffgnar
biffgnar's Avatar
You have front and rear swaybars and front and rear trackbars. With 4" of lift your axle displacement is probably enough that you will want adjustable trackbars to recenter axle under jeep. Keep rear swaybar. Removing it is not going to add anything offroad and will give you a little more body roll onroad. Maybe check the links to make sure they are long enough but after doing that just leave the rear alone. On the front discos is a good cheap option for offroad. If you have the $$s go to an offroad swaybar (e.g. Antirock) or a dual rate swaybar (e.g. Swayloc).
Romney in 2020!
biffgnar is offline
post #5 of 6 Old 07-11-2010, 08:28 AM
MisfitSeven
MAiL Crawler.
MisfitSeven's Avatar
yes you have a front and rear track bar. you need both of them.
keep the rear sway bar. it is flexy enough to keep connected even when off road. you will want the stability of it connected for when you are on a side hill. invest in some discos for the front, or an anti-rock.
you need adjustable track bars for lifts over 3". you can adjust them to keep your axles centered. otherwise just reuse the factory track bars.
Mail crawling.
MisfitSeven is offline
post #6 of 6 Old 07-11-2010, 08:38 AM
robncar
robncar's Avatar
Front and rear adjustable trackbars - Will allow you to re-center the axles post lift. Due to the trackbars on the TJ, when you lift the axles move off center. The adj. TB's will mitigate this issue.
Front and rear sway bars - Either run front discos or replace with Currie AntiRock. Leave rear connected but make sure the end links are the correct length for your lift.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
sway , track , bar , removal , no
Death Wobble, track bars, sway bars, etc. Roadhustler63 YJ Wrangler Technical Forum 5 07-04-2010 01:38 PM
sway bars, track bars....WTF!!! skipilot YJ Wrangler Technical Forum 4 03-01-2009 09:57 PM
track bar/sway bars, do u need them? jackel18 YJ Wrangler Technical Forum 38 07-09-2006 09:37 PM
Shackles, Track Bars and Sway Bars dabomb5756 YJ Wrangler Technical Forum 23 05-02-2005 10:22 PM
Disco's Sway Bars and Track bars biffstephens TJ Wrangler Technical Forum 1 10-23-2004 04:34 AM
