Sway bar quick disconnects bolt - JeepForum.com
post #1 of 11 Old 03-26-2011, 07:00 PM Thread Starter
bossdj06
Anyone know where I can get a quick disconnect bolt. Shown here is with the bolt, and without. I don't want to use a regular bolt. Is there a place where I can order this? Just need the bolt.
bossdj06 is offline
post #2 of 11 Old 04-10-2011, 08:52 AM Thread Starter
bossdj06
Anyone?
bossdj06 is offline
post #3 of 11 Old 04-10-2011, 08:56 AM
WV_Boltman
2011 JK Wrangler
check around at a hardware store, or do this, it's probably alot cheaper than buyin a bolt from a lift company
http://www.4x4xplor.com/homediscos.html
WV_Boltman is offline
post #4 of 11 Old 04-10-2011, 08:57 AM
BrianBFD
Not trying to oversimplify here, but couldn't you remove the one you have, take it to a hardware store and get another one just like?
If fishing is a sport, does that make me an athlete?
BrianBFD is offline
post #5 of 11 Old 04-10-2011, 09:02 AM Thread Starter
bossdj06
I've looked around hardware stores and couldn't find anything. I'll look again. I def don't want to use a regular bolt though.
bossdj06 is offline
post #6 of 11 Old 04-10-2011, 09:10 AM
duanewhatley
I dont understand regular bolt? Just go to hardware store and get a grade 5 or 8 bolt.
duanewhatley is offline
post #7 of 11 Old 04-10-2011, 09:14 AM Thread Starter
bossdj06
I've tried using a grade 5 bolt. I need one specifically designed to fit the rubber of the disconnect. Regular bolts (grade 5,8) don't work. Need to know where to get this specially designed bolt. Thanks.
bossdj06 is offline
post #8 of 11 Old 04-10-2011, 09:26 AM
F9K9
F9K9's Avatar
If, You are talking about "F" in the diagram below then You have no alternative but, to order from JKS.
For those who have fought for it, FREEDOM has a taste that the protected will never know."
'03 Rubicon w/a few changes.
F9K9 is offline
post #9 of 11 Old 04-10-2011, 09:59 AM Thread Starter
bossdj06
Cool I will order it from them. Thanks!
bossdj06 is offline
post #10 of 11 Old 04-11-2011, 01:04 PM
flipper349
they are called lift pins you can get them from tsc or a tractor supply. thay also have bushings for different sizes
flipper349 is offline
post #11 of 11 Old 04-12-2011, 03:22 PM Thread Starter
bossdj06
Thank you this helped a lot!
bossdj06 is offline
bar , bolt , disconnects , quick , sway
Quick Disconnects Sway inflatus TJ Wrangler Technical Forum 8 04-28-2010 01:06 AM
Sway bar Quick disconnects wildchild YJ Wrangler Technical Forum 13 01-14-2008 05:30 PM
Who is using sway bar quick disconnects N2rock JK Wrangler Technical Forum 22 10-24-2007 12:49 PM
sway bar quick disconnects Bduke911 TJ Wrangler Technical Forum 8 01-15-2007 04:52 PM
