Sway Bar Links! - JeepForum.com
post #1 of 13 Old 11-10-2002, 05:36 PM Thread Starter
UniSonic23
Sway Bar Links!
I'm in need of some sway bar links
Anyone know where i can get some used ones in good shape or even some quick disconnects.
If anyone has some ideas or help, i'd appreciate it
'97 Flame Red TJ Stock 4.0l
w/30 X 9.5 Kelly Safari AWR
2003 Model Center Console SUB
Soft and Hard Top
UniSonic23 is offline
post #2 of 13 Old 11-10-2002, 05:39 PM Thread Starter
UniSonic23
by the way my jeep is completly stock underneath, that's why i don't really want to buy new ones, i am gonna lift it eventually prolly a year when i am outta school
Soft and Hard Top
post #3 of 13 Old 11-10-2002, 05:56 PM
Jeepchik
You can make your own disconnects.....they have a write-up at www.rockcrawler.com
In their tech section under cheap tricks it shows you how to make them and everything you will need to do it....cheap and easy
Green Jeep Club Member #1
Jeepchik is offline
post #4 of 13 Old 11-10-2002, 05:56 PM
thecarman
What exactly are sway bar links?
1994 Jeep Wrangler 2.5L (White)
thecarman is offline
post #5 of 13 Old 11-10-2002, 06:01 PM
Bob J
Bob J's Avatar
1984
I might still have them, I'll have to check my bin of stock parts.
this is a sway bar link, also know as a stabalizer link.
1984 AMC Eagle
2006 TrailBlazer
Sig v.55
Bob J is offline
post #6 of 13 Old 11-10-2002, 06:02 PM
Jeepchik
They are what holds your swaybar to your axle....if you look on top of your bumper under that little plastic jeep thingy there is a bar that runs under it....that is the swaybar....now if you look behind the bumper you will see where the swaybar comes down...the links are the things that come down from the swaybar and connect to the axle....by disconnecting these it allows for more wheel travel offroad.....check out that link I posted and it will show you exactly what I am talking about.....hth
Jeepchik is offline
post #7 of 13 Old 11-10-2002, 06:05 PM
thecarman
Thanks for the explaination and picture. Learn new things everyday!
post #8 of 13 Old 11-10-2002, 09:08 PM
rbowling
rbowling's Avatar
I will probably have my pretty much brand new ones for sale in a couple weeks off of my 2002, once I lift my jeep if you can wait...
Email me at bowling1@rcn.com
Thank You
Richie
02 TJ Black
Stock ..... for now
rbowling is offline
post #9 of 13 Old 11-10-2002, 10:06 PM Thread Starter
UniSonic23
i'll take anything i can get...and jeepchik mine are broken
http://www.geocities.com/unisonic23/discos.htm
but i don't have any on there right now so i need them asap
it rides like an old caddy "boat" with them off
Soft and Hard Top
post #10 of 13 Old 11-10-2002, 10:10 PM Thread Starter
UniSonic23
although with them off
check this out!!
Soft and Hard Top
post #11 of 13 Old 11-10-2002, 10:11 PM
Jeepchik
Oops my bad!! I never said I was smart
Jeepchik is offline
post #12 of 13 Old 11-10-2002, 10:47 PM
cptn_mrgn78
cptn_mrgn78's Avatar
Since yours are broken, you might want to take a look at some QD's. I know that there are adjustable models.
RIP: '97 TJ with 2in Teraflex with QD's. 32in AT's. Hi-lift jack, two 10in subs and a 500 watt amp. 150watt KC Daylighters. Avalanche Engineering Rocker Knockers.
New: '05 Unlimited
cptn_mrgn78 is offline
post #13 of 13 Old 11-12-2002, 06:12 AM Thread Starter
UniSonic23
i am all set i found some in clearwater florida
they'll be here by this weekend
thanks though
Soft and Hard Top
sway , bar , link
Sway bar links mikesbeachhut TJ Wrangler Technical Forum 5 11-16-2009 11:58 PM
Sway Bar and Sway Bar Links -- MOOG? mmitsch TJ Wrangler Technical Forum 9 08-09-2009 11:21 PM
sway bar links? JeSimmers TJ Wrangler Technical Forum 10 12-27-2007 07:14 AM
sway bar links skier518 TJ Wrangler Technical Forum 6 08-12-2006 01:44 PM
Sway Bar links 98kkk TJ Wrangler Technical Forum 2 08-02-2006 08:22 PM
