Sway Bar Bushing is Bad - JeepForum.com
post #1 of 23 Old 09-22-2011, 10:47 PM Thread Starter
99TJNC
My front driverside sway bar bushing has gone bad, so I'm going to replace it this weekend. It started off as a slight noise when I hit bumps, but has gotten much worse to where I cringe the entire time I'm driving the Jeep.
Tonight I unbolted the top of the sway bar, but I haven't disconnected it yet, I just have my Jeep sitting outside of my apartment. Will it be ok for me to disconnect my sway bar and drive short distances until I get the part? I've never driven with the sway bar disconnected as I haven't gone wheeling or anything yet. So will this be ok around town or should I just get a ride to the store?
Thanks,
Matt
PI KAPPA PHI
1999 SE - Zone BB - 31x10.50 MasterCraft Courser R2's - Delta Quad Bar's
"It's better to be tried by 12 than carried by 6"
99TJNC is offline
post #2 of 23 Old 09-22-2011, 11:07 PM
pcoplin
pcoplin's Avatar
You'll be fine for short distances. Just make sure you take both sides off and zip-tie the swaybar out of the way. The rig will lean quite a bt, so take it easy.
pcoplin is offline
post #3 of 23 Old 09-22-2011, 11:30 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
you'll be fine. just don't hot rod around corners. first time you pull left out into traffic with your foot hard on the throttle, you'll notice a clear difference as the Jeep leans over a bit more than normal
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #4 of 23 Old 09-23-2011, 08:06 AM Thread Starter
99TJNC
So once I unbolt the other side, do I just jack the Jeep up and knock them down until they are free swinging, and then zip tie them ?
PI KAPPA PHI
99TJNC is offline
post #5 of 23 Old 09-23-2011, 08:08 AM
Unlimited04
you dont use a jack at all. unbolt the bottoms of the links, slide the link off. if you unbolt the top two metric bolts on the sway bar on each side of the frame, the whole damn thing will lift right off.
Useful Write-Ups:
Funny:
post #6 of 23 Old 09-23-2011, 08:12 AM Thread Starter
99TJNC
Oh ok. I'm only doing this to replace the bushing on the top because it is SHOT and sounds like my entire Jeep is going to fall apart on every bump. So to replace that bushing, I thought I needed to unbolt the top. Am I wrong and just need to unbolt the bottom?
PI KAPPA PHI
99TJNC is offline
post #7 of 23 Old 09-23-2011, 08:14 AM
Unlimited04
yes, you'll need to pull the whole sway bar off, remove the rubber bushing, install the new rubber bushing, and bolt it all back up. but like I said, you don't need to use a jack at all.
Useful Write-Ups:
Funny:
post #8 of 23 Old 09-23-2011, 08:41 AM Thread Starter
99TJNC
Ok good, because I don't know that I trust the jack that came with the Jeep. The bushing started off bad but has gotten much worse, so how likely is it that the link has gotten messed up as well as the bushing?
PI KAPPA PHI
99TJNC is offline
post #9 of 23 Old 09-23-2011, 08:44 AM
private
If they're stock links (the ball and socket design), as long it isnt seperated they're fine.
1998 TJ 2.5 5spd
private is offline
post #10 of 23 Old 09-23-2011, 08:54 AM Thread Starter
99TJNC
they are the stock links, and when I rock the Jeep back and forth, the bushing looks like it separates into two pieces and then when the weight comes back down on this side, there is a grinding noise and a loud pop and bang.
PI KAPPA PHI
99TJNC is offline
post #11 of 23 Old 09-23-2011, 09:18 AM
Unlimited04
sounds like a good chance to upgrade to a set of JKS disconnects.
Useful Write-Ups:
Funny:
post #12 of 23 Old 09-23-2011, 09:26 AM Thread Starter
99TJNC
Is this a good idea even though I have no lift? and When I do lift it, probably in the next month or two, will these discos work with the lift? I'm getting the 3 inch Zone lift if it makes a difference.
PI KAPPA PHI
99TJNC is offline
post #13 of 23 Old 09-23-2011, 09:35 AM
troy.j
That, if you ever plan to wheel it that is.
99 tj, 00 wj, 95 yj
...ask those who have bled of the cost of freedom and honor those who gave that others may have what we take for granted...
troy.j is offline
post #14 of 23 Old 09-23-2011, 12:56 PM
NakedCreekTJ
Yea I've had my jeep for about a month and never had sway bar connects so mine just hangs. But it drives just fine. So yea take em off I personally like it better but everyone has their own taste. Either way though I need to get some discos so I can pass inspection. Lol. Any advice on that? My sway bar where it connects has hole on top and bottom instead of the sides. So I'm puzzled about how its gonna work.
___ ___
[l_,[____],
l---L - OllllllO-
( )_) ( )_)--)_)
NakedCreekTJ is offline
post #15 of 23 Old 09-25-2011, 09:59 PM Thread Starter
99TJNC
I replaced the link today with a cheap one from Advanced Auto and the problem is solved! my Old link was SHOT. Both the bushing and the link was damaged.
PI KAPPA PHI
99TJNC is offline
sway bar bushing strap jsl3824 YJ Wrangler Technical Forum 0 03-12-2009 08:10 PM
Sway bar bushing ? Jeepster197 YJ Wrangler Technical Forum 1 03-04-2007 05:14 PM
sway bar bushing NCJEEPFAN TJ Wrangler Technical Forum 4 07-06-2006 11:41 AM
Sway bar bushing ?? rvn4fun TJ Wrangler Technical Forum 6 06-23-2005 09:10 AM
Sway Bar Bushing replacement Optik45 TJ Wrangler Technical Forum 4 07-15-2004 09:39 AM
