Swar bar help - JeepForum.com
post #1 of 14 Old 08-05-2011, 08:17 PM Thread Starter
jonnyb1984
Swar bar help
I started hearing a clunking when I turn to the left or going over a bump. Through some research I'm about 95% sure it's the sway bar as it clunks when I rock it from side to side. I haven't been able to find any information about how to fix this problem though. Any help would be appreciated. Thanks.
jonnyb1984 is offline
post #2 of 14 Old 08-05-2011, 08:18 PM
biffgnar
biffgnar's Avatar
Responsible options are replace with stock links, replace with quick disconnects or replace with antirock/dual rate swaybar.
Romney in 2020!
biffgnar is online now
post #3 of 14 Old 08-05-2011, 08:29 PM Thread Starter
jonnyb1984
I went out and looked as i rocked it and I see the one that is loose. I'm a little tired so I didn't think to do that before I just rocked it back and forth. I'll look in to those options. There's a jeep guy at one of the places I go, maybe he'll be there tomorrow. Thanks for your help.
post #4 of 14 Old 08-05-2011, 08:46 PM Thread Starter
jonnyb1984
which would you recommend, the disconnects or the antirock sway bar?
post #5 of 14 Old 08-06-2011, 02:03 AM
sar50
I had a broken sway when I purchased my jeep. I put an Anti-Rock on the front and have been very pleased. I run an RE 3.5 lift and with the Anti-rock in the middle hole, I can still get full flex out of my suspension.
sar50 is offline
post #6 of 14 Old 08-07-2011, 12:12 AM Thread Starter
jonnyb1984
is it really bad to drive with it clunking like that? I'm about to get a new job and will be moving shortly and might not have time to change it out...i was just going to get a cheap one and put it in just until i had some time and a little bit more money for an Anti-Rock...it doesn't sound very good driving around.
post #7 of 14 Old 08-07-2011, 01:12 PM
biffgnar
biffgnar's Avatar
If you are going to drive it, I'd take the link out entirely so its not banging things up under there. You're going to have a lot more body roll in corners without link connected. Wouldn't recommend it for an extended period of time for general onroad, safety reasons, but in and of itself its not going to hurt your vehicle.
Romney in 2020!
post #8 of 14 Old 08-07-2011, 04:30 PM
mquerry
Are you using the stock link? If so, is it just a loose bolt? If after-market, how do the bushings look?
mquerry is offline
post #9 of 14 Old 08-09-2011, 02:37 PM Thread Starter
jonnyb1984
It's a stock link and I got another cheap one to put on until I get the job thing settled and I have some cash coming in for something better. I do however have another problem now...I have a nut that is stuck. It doesn't look too badly rusted but I've been spraying it with wd-40 for about 2 days now, tapping it with hammer, heating it up...I'm about out of things to try so if anybody has any tips on that I'd appreciate it as well.
post #10 of 14 Old 08-09-2011, 02:41 PM Thread Starter
jonnyb1984
I think my next resort is to get a nut splitter and just be careful using it so I don't screw up the threads on the bolt.
post #11 of 14 Old 08-09-2011, 02:41 PM
biffgnar
biffgnar's Avatar
Which nut is it? If its either of the nuts on the stock links I would think you should be able to get a nut splitter on it and just crack it off.
Romney in 2020!
post #12 of 14 Old 08-09-2011, 02:57 PM Thread Starter
jonnyb1984
it's the 18mm one that comes with the link, which is why i was contemplating on just using the nut splitter. One more trip to the store.
post #13 of 14 Old 08-09-2011, 04:29 PM Thread Starter
jonnyb1984
Ok got that pesky nut unstuck and I'm at the last obstacle. The top part of the link was separated from the bottom...I got the bottom part off, but the top part is stuck on the sway bar. Does that top part screw in there or does it just feed through? If it screws in I might be stuck enough to where I have to take it to a shop...i currently have it soaking with lubricant. Thanks again everybody.
post #14 of 14 Old 08-09-2011, 04:31 PM
biffgnar
biffgnar's Avatar
Its a tapered bolt so it will be in there good. If you do a search there are plenty of threads about how people get those out, but options include pickle fork, pitman arm puller, whacking the corner of the sway bar (not the bolt) with a BFH, etc.
Romney in 2020!
bar , clunk , fix , sway , turning
