swapping open carrier for limited slip? - JeepForum.com
post #1 of 2 Old 10-04-2013, 08:38 AM Thread Starter
eekey
Before I get to deep in to this project I want to make sure I'm not waisting my time. My rear pinion gear shattered.
I have a Dana 44 axle, currently it is open. I got a hold of a used limited slip carrier. If I rebuild it with new ring and pinion and spider gears will it fit with out swapping out any thing else? If it fits I will be taking it to a professional to have it installed. I don't think I want to touch that.
thank you
eekey is offline
post #2 of 2 Old 10-04-2013, 11:30 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
it should fit, provided you've got the right part. there were some variations between D44s, so look up the compatibility with the LSD's manufacturer.
to install it is another gear setup...so setting backlash, pinion depth, master install kit, etc.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
