Swapping front Coil Springs - JeepForum.com
post #1 of 6 Old 06-13-2006, 05:07 AM Thread Starter
alt13
alright, here's the deal, i've got a '97 4cyl TJ, with a 2" spacer lift all around. this setup was great at first, but i recently installed a 9500lb mile Marker winch, and due to the extra weight the front end looks to be stting lower, still no big deal, no tire rub when articulated or anything, i just don't like how it looks. I saw in another thread that someone swapped in front coils from a XJ and said they were taller, and i wanna know how much taller are we talking? and are they really taller or just a stiffer spring? If this is a good solution i'm set cause there are 3 XJ's back home on the farm, 2 just waiting for me to take them apart!!
alt13 is offline
post #2 of 6 Old 06-13-2006, 05:42 AM
matt3liv
1984 CJ8
or, you could just swap in some stiffer TJ springs. I have an 03 SE. It has a BB, and the stock 127 springs up front. I have a Warn M6000 on the front and it sags a little bit. I'm looking for some 130 springs for the front now.
matt3liv is offline
post #3 of 6 Old 06-13-2006, 07:17 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Stock Cherokee springs will give you 1.5" - 2" of lift.
Grand Cherokee springs from a V8 model will give you around 3" of lift. If they come from an I6 model, it will be closer to 2" - 2.5" of lift.
Wheelin98TJ is offline
post #4 of 6 Old 06-13-2006, 07:53 AM
Tinker
Tinker's Avatar
OK, but, is thye lift due to a taller spring or is it due to a stiffer spring. I have the same setup as the first poster and I have the 6 cyl. springs already (129's), and I still need just a bit more.
"Does this look broken to you?"
Tinker is offline
post #5 of 6 Old 06-13-2006, 08:54 AM
Wheelin98TJ
JEEP FREAK
Both longer and higher spring rate, but mostly due to the higher spring rate.
If you're concerned about ride quality, I don't think you'll notice a difference.
We did this to my friends TJ about 3 years ago and ended up using V8 ZJ springs in the front (no spacer) and a 2" spacer in the rear. It sat perfectly level like this.
post #6 of 6 Old 06-13-2006, 09:10 AM
markc522
just get rusty's 3" springs.
this is a pretty common thing to do.
$100 bucks and no guessing if your spring rate/length is going to work.
2003 wrangler x
somewhere around a 4" frakenlift -
33" claws - black soft 8's - dt8000's - disco's
yellow jeep club member #874
JEEP:
markc522 is offline
Bowed Front Coil Springs pfifer TJ Wrangler Technical Forum 21 09-17-2010 03:01 PM
i have spacers on top of my front coil springs cmandes13 TJ Wrangler Technical Forum 11 01-27-2009 05:42 PM
Front coil lift springs TheBoogieman TJ Wrangler Technical Forum 3 08-05-2007 11:26 AM
GC front coil springs TheBoogieman TJ Wrangler Technical Forum 4 07-21-2007 05:45 PM
Unable to Remove Front Coil Springs Trombino TJ Wrangler Technical Forum 7 04-02-2006 11:45 AM
