Swapping caps on a u-joint. - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Swapping caps on a u-joint.
Spartan Lockers FREE SHIPPING Excellent PricesRough Country Jeep Suspension Deals at Rockridge 4WD!Amsteel Blue Synthetic Winch line Free Shipping
Unread 04-27-2012, 05:04 PM   #1
athos76
Well, the other day I knocked out my RMS. While removing my FDS for a little better access, one of the front u-joint caps fell off and needle bearings went everywhere. The u-joint is still in the driveshaft, it was just the cap that attaches with the straps to the front yoke. The question is, I have a spare Tom Woods u-joint that has a couple hundred miles on it... should I swap the whole unit, or just throw the cap with bearings onto the missing one.
2006 I6 6-Speed X, 33" Goodyear Duratrac, RC 3.25" lift, Windstar CAI, York OBA (in progress), custom corner guards (in progress)
Stupidity is NOT a crime... therefore you're free to go.
Support STU-OFFROAD NOW!!!
athos76 is offline   Reply With Quote
Unread 04-27-2012, 05:17 PM   #2
RaggedOleMan
Don't put the original cap back on unless you have ALL the needle bearings, you're asking for trouble if you do. The Spicer 153x is the u-joint you need, and they should be about $12 +/-. Or if you're comfortable with the Tom Woods flavor, put it on.
RaggedOleMan is offline   Reply With Quote
Unread 04-27-2012, 05:23 PM   #3
greene69
Beach Bound
greene69's Avatar
I would just get another u-joint to be safe and replace it while it's out. You don't need to chance getting alitttle dirt or something in it.
It's better to be dead and cool than alive and uncool.
Nothing like a permanent reminder of a temporary feeling. I have a few.
4.0 auto, 8.8 rear with detroit locker, 4.10's and 33x 12.50's
greene69 is online now   Reply With Quote
Unread 04-27-2012, 05:50 PM   #4
athos76
Let me clarify:
The original cap is not a factor... It's trash
Both u-joints are Tom woods gold seals.
Would it be ok to swap the cap and bearings from the known good u-joint to the u-joint missing the cap?
Unread 04-27-2012, 05:51 PM   #5
justanotherjpr
Install a new joint
justanotherjpr is offline   Reply With Quote
Unread 04-27-2012, 06:37 PM   #6
RaggedOleMan
You really shouldn't swap the cap/trunnion if it can be avoided. In a pinch to get off the trail ,that's one thing. But if you have a replacement joint handy it's in your best interest to swap it out in its entirety. Either that of find them itty bitty needle bearings! I've done it myself...
EDIT: Now that I think about it, I've done what you're proposing with a Spicer 760 without the world coming to an end. The deal is, I believe, that there's a very specific, measured amount of grease in each cap from Spicer. Presumably from Tom Woods, too. That said, if you're feeling lazy just swap the cap. You'll know sooner or later if it was wise. In my case, with my 760's, (axle u-joint) it never became an issue.
Unread 04-27-2012, 06:53 PM   #7
athos76
The Tom Woods Gold Seals have a zerk fitting to grease them. Since they are the same type/brand/model... I'll swap out the cap for now... The needle bearings on the old cap scattered to every corner of the shop.
Unread 04-27-2012, 07:22 PM   #8
SlackJaw
SlackJaw's Avatar
Lol clarification made the difference
SlackJaw is offline   Reply With Quote
