swapping to 3.5 inch springs? - JeepForum.com
post #1 of 17 Old 10-12-2008, 04:48 PM Thread Starter
deryk111
I was gonig to order the 4.5 rubicon express superflex lift. i was told to swap to the 3.5 inch springs but get the 4.5 kit because its more complete in another thread. But if im going to order the 4.5 kit why swap the springs and just keep the 4.5 inch ones? Whats the point of swapping? Or is it becuase the 3.5 springs will look better with 33" tires and would look weird with 4.5" springs?
deryk111 is offline
post #2 of 17 Old 10-12-2008, 06:09 PM
RnEmOvr
Have Cummins, Will tow.
RnEmOvr's Avatar
the 3.5s are almost to much for 33s even, i know guys running them and 35s with no BL and no rubbing and no extra bumpstop
RnEmOvr is offline
post #3 of 17 Old 10-12-2008, 06:14 PM Thread Starter
deryk111
really? So your saying the 3.5 inch springs is diffinatly plenty enough for 33 inch tires and even enough for 35's? so then the 3.5 inch springs would probably be the way for me to go then since the 33's would be better on my stock axles right?
deryk111 is offline
post #4 of 17 Old 10-12-2008, 06:16 PM
RnEmOvr
RnEmOvr's Avatar
by far, just stay with the 3.5, if you decide 35s then do flat fenders (like brian did) or add 1" BL (like dave did)
RnEmOvr is offline
post #5 of 17 Old 10-12-2008, 06:32 PM Thread Starter
deryk111
ya i was going to go with tube fenders anyways, but the 3.5 inch springs will make the jeep look big and your postive?
deryk111 is offline
post #6 of 17 Old 10-12-2008, 06:35 PM
RnEmOvr
RnEmOvr's Avatar
you dont need the 4.5 for 33s, but if all you want is looks then by all mean go to high and get laughed at for having to much lift and to little tires, search the "what does my jeep look like with X lift" pics of both sets ups are in there
RnEmOvr is offline
post #7 of 17 Old 10-12-2008, 06:39 PM Thread Starter
deryk111
no mi not doing it for looks im just saying. And i was getting the 4.5 inch superlfex kit but swapping the springs for the 3.5, i just wanna make sure that the jeep is going to be big enough for the off road use im using it for.
deryk111 is offline
post #8 of 17 Old 10-12-2008, 06:42 PM
RnEmOvr
RnEmOvr's Avatar
the guys i knew with this did WEROCK comps and the never rubbed, the 3.5 kits nets over 4"
RnEmOvr is offline
post #9 of 17 Old 10-12-2008, 06:52 PM Thread Starter
deryk111
right, but like i said im not getting the 3.5 kit. im getting the 4.5 kit and just swaping the srpings to 3.5" but still having the 4.5 inch kit so my lift is more complete
deryk111 is offline
post #10 of 17 Old 10-12-2008, 06:58 PM
RnEmOvr
RnEmOvr's Avatar
i understand, you still will have plenty of room, you are not loosing any of the 3.5" lift, the only thing different is the 4.5 kit adds stuff to help you out, you will be fine,
RnEmOvr is offline
post #11 of 17 Old 10-12-2008, 07:00 PM Thread Starter
deryk111
what do you mean not losing any of the 3.5 inch lift? you mean the 4.5?
deryk111 is offline
post #12 of 17 Old 10-12-2008, 07:03 PM
RnEmOvr
RnEmOvr's Avatar
if you take the 3.5" kit and measure it you will get 4.25" (for sake of arguement we will use that number, but it is close to real net gains), if you take the 4.5" kit but use 3.5" springs you will still get 4.25" of lift,
RnEmOvr is offline
post #13 of 17 Old 10-12-2008, 07:06 PM
BLK2000TJ
The 3.5 springs are perfect for 33" tires.
2010 JKU Rubicon 3.5" AEV , AEV Pintlers 35" KM2's , AEV Bumpers, AEV Hood / Snorkel
2008 JKU (Daily Driver)
2000 TJ Auto 4.5 RE Superflex ,35" MTZ 's , Warn ,Viking, LoD, RockHard,AEV, JKS, ARB's, Vanco Big Brake Kit ,Currie etc. etc.etc.
BLK2000TJ is offline
post #14 of 17 Old 10-12-2008, 07:08 PM
RnEmOvr
RnEmOvr's Avatar
all the 4.5" kit adds is front track bar and upper control arms,
RnEmOvr is offline
post #15 of 17 Old 10-12-2008, 09:30 PM
lucasinpsj
lucasinpsj's Avatar
here is a picture of mine with 4.5 springs and a 1.25 body lift. tires are 35 mtrs. i figure i netted close to 6" with the springs.
2005 red unlimited, 6 speed on 40" MTR Kevlars w/ Raceline beadlocks..... Stuff from rokmen, currie and jks.
lucasinpsj is offline
Writeup for swapping springs computerguy JK Wrangler Technical Forum 19 02-12-2010 01:23 PM
4 inch springs with 1 inch spacer? will it work? 99TJtommy TJ Wrangler Technical Forum 19 11-17-2009 08:23 PM
Swapping out springs? IH8ROADZ TJ Wrangler Technical Forum 12 10-30-2008 09:59 PM
springs, axles, and swapping? jmathis3 YJ Wrangler Technical Forum 8 02-14-2008 10:35 AM
Swapping front Coil Springs alt13 TJ Wrangler Technical Forum 5 06-13-2006 09:10 AM
