Swap 97-98 TJ tub on my 04 RUBI - JeepForum.com
post #1 of 3 Old 07-19-2010, 03:12 PM Thread Starter
rocjunkie
I rolled my 04' Rubicon and am looking to swap an older 97-98 TJ tub onto my 04' Rubicon frame. Does anybody know if it will fit or do I have to use an 03-06 tub? I would be ok with drilling a couple new holes to make it fit. Any help would be appreciated.
rocjunkie is offline
post #2 of 3 Old 07-19-2010, 04:10 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It will fit and work just fine with no drilling or modifications needed if you are only doing the body work, tub, grill, fender's etc.
There are some frame and skid changes between the two different years, but nothing that should affect you unless you get a 98.
The 98 has shorter grill snubbers that sit on a bent piece of flat sheet metal that wraps over the frame. You will need the snubbers from a 98 or remove the little platform from the frame.
I am Savvy
blackmagicbrakes.com
mrblaine is offline
post #3 of 3 Old 07-20-2010, 12:31 AM Thread Starter
rocjunkie
excellent. thank you.
tj , wrangler , tub , swap , rubicon , fit
Rubi swap / Axle swap (merged) tjmike TJ Wrangler Technical Forum 5 06-10-2010 01:04 PM
Rubi 44 swap out question??? draganov TJ Wrangler Technical Forum 7 12-29-2008 11:55 AM
did my rubi d44 swap, but theres a problem?!? 97casteeltj TJ Wrangler Technical Forum 5 05-20-2008 07:21 PM
D35 to Rubi D44 Swap Milhouse TJ Wrangler Technical Forum 6 03-21-2007 08:40 AM
Gear swap, Rubi D44 to TJ D44 Sbeltinc TJ Wrangler Technical Forum 3 10-17-2006 02:36 PM
