Suspension Question!! How to install coil spacers - JeepForum.com
post #1 of 5 Old 08-05-2010, 12:07 PM Thread Starter
DaRayvn
I bought some of the poly spacers to lift my jeep up 2" just so i have a little more tire clearence for the 31" tires. My question is, do i have to drop the front end and dissconnect the spring arms, track bar, and all that other stuff to get the coil springs out just to put the spacers in?? Or can i just use a coil spring compressor to compress the spring small enough to slide the spacer in up top? Any info id appreciate...
DaRayvn is offline
post #2 of 5 Old 08-05-2010, 01:00 PM
Ggg
IMO it is safest to just disconnect the shocks, sway bar, and maybe the track bar. Then just jack up the frame until there is enough room to install the spacers. The link arms should not need to be removed.
I really do not like to use coil spring compressors if at all possible.
Ggg is offline
post #3 of 5 Old 08-05-2010, 08:39 PM Thread Starter
DaRayvn
IMO?? sorry i dunno what that is lol...Whats bad about the spring compressor?? im just curious. Just possibly damaging the spring? Or does it take away some of the spring stiffness?? Im new to all this suspension stuff so sorry if my questions seem kinda like car knowledge 101 lol. I looked at my shocks and i dunno if its just me but they dont look like shocks lol well maybe half of a shock?? The pic is of the front and the back is the same but bigger coil springs. Based on the pic is there anything you can tell me?? Would i just slide the spacer over that and then the spring sits right on the spacer? Also where would be the best place to jack up the frame?? could i do it from the front axle or the frame along the side right under the doors? Again i apologize if im asking dumb questions. Im trying to become more versed in suspensions lol I appreciate the response. Anything else you can tell me would help a lot. Im spraying the underbody with the linex that they spray truck beds with so id like to get the spacers in the same day. Thanks.
DaRayvn is offline
post #4 of 5 Old 08-05-2010, 10:42 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
You do not need spring compressors.
Here is a good how-to on installing coil spacers:
Rubicon Express 2" Budget Boost Installation Write-Up for Jeep TJ
Wheelin98TJ is offline
post #5 of 5 Old 09-23-2010, 01:02 PM
nikeo02
Thats not your shock, thats what prevents you from bottoming out, its a bumper/stop. Your shock is actually the black tube behind it in that photo.
2003 Yellow TJ
nikeo02 is offline
suspension , install , spacers , bb , budget boost , tj , wrangler , compressors
Pros and cons of coil spacers vs suspension lift bradp8 TJ Wrangler Technical Forum 16 11-30-2011 10:48 AM
Coil spacers with a suspension lift? Houndx TJ Wrangler Technical Forum 18 12-11-2009 07:44 AM
Adding coil spacers to RC 2.5 Suspension Lift gpower77 TJ Wrangler Technical Forum 17 08-24-2009 11:46 AM
Coil spacers a suspension lift? ribs TJ Wrangler Technical Forum 5 05-01-2008 11:42 AM
adding coil spacers to suspension lift stingray TJ Wrangler Technical Forum 5 07-24-2005 03:44 AM
