Is suspension lift required to swap in a HP Dana 30? - JeepForum.com
post #1 of 4 Old 09-11-2009, 09:23 AM Thread Starter
TJ_ITmgr
Is suspension lift required to swap in a HP Dana 30? I've seen mention of this all over the threads i've searched but i have never found an difinitive(sp?) answer.
Does it matter if it disconect of non-disconect?
Thanks,
1997 TJ, 4.0, 5 Spd, Low miles, Rough Country 2.5" Suspension Lift, 3in body lift, Mega Short SYE and custom shaft, 33x12.50 Maxxis Bighorns, 15x8 Soft 8's, 8.8 Rear w/LS, HP D30 w/LockRight and 3.73's
TJ_ITmgr is offline
post #2 of 4 Old 09-11-2009, 09:30 AM
Sobie
Bolt-on Maniac
Sobie's Avatar
if it fit in an xj with no lift, it should fit in a tj with no lift. get the non disconect housing.
Sobie is offline
post #3 of 4 Old 09-11-2009, 12:20 PM Thread Starter
TJ_ITmgr
Anyone with any experience know for sure?
Do i have to get adjustable control arms?
TJ_ITmgr is offline
post #4 of 4 Old 09-11-2009, 01:18 PM
Imped
Imped's Avatar
I have a HP D30 with 2.5" of susp. lift. You'll be fine without any lift. No NEED for adj. control arms but they sure wouldn't hurt.
OlllllllO
IndyORV
Imped is online now
Required Parts for 4 inch suspension jakevisscher TJ Wrangler Technical Forum 2 11-20-2009 01:45 PM
What is required IN DETAIL for a 1995 5-Speed YJ 2.5L I-4 Swap To 4.0L I-6? wick001 YJ Wrangler Technical Forum 7 09-12-2008 03:48 PM
Door Swap/Lock Advice Required Harvey Jay TJ Wrangler Technical Forum 0 10-23-2006 05:04 PM
SYE required for Suspension and Tires??? Thump85 TJ Wrangler Technical Forum 21 03-05-2006 08:22 PM
SYE required for a 2.5" suspension lift? RT8827 YJ Wrangler Technical Forum 7 07-15-2003 08:46 AM
