Quantcast Suspension Lift, Body Lift Questions - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Suspension Lift, Body Lift Questions
Truck-Lite's New LED Headlamp Series4.25" 97-06 Jeep TJ Wrangler Lift Kit - NO SYE NeededRuffstuff Axle Simple Swap Kit!
Old 06-12-2005, 02:47 PM   #1
CityJeep
Earlier I posted a thread about lifting my jeep, but for mostly visual puposes, the occasional mudding and swamping, no off-roading. I got a lot of response's advising against 35's with a 4" lift because it was simply not necessary, which is probably true but I though I'd ask.
From what I here more modifications are needed with 4" and more suspension lifts. Is this also the case with Suspension and Body lift combinations?
I first wanted a 4" suspension and a 1" body, but would there be less area for concern if I had a 3" suspension and a 2" body? I'm new to lifts so I might as well the questions now before making the wrong decision.
CityJeep is offline   Reply With Quote
Old 06-12-2005, 04:49 PM   #2
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
Well, it's at about the 4" suspension lift height where lifting gets expensive because at that height, you start needing a SYE kit and longer CV driveshaft to cure the vibrations and replace the driveshaft which becomes too short at that height.
So if you needed over 3" of height, a 3" suspension lift and a 1" or 2" body lift would get you around the need for the SYE and CV driveshaft. It's not a bad way to go.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 06-12-2005, 04:52 PM   #3
UAJeep
Why do you want to go that high if you are offroading only occasionally?
1999 TJ, 4.0, 5 Spd., 3" BDS, 33 X 12.50 BFG A/T, 4.10 gears w/ Truetrac on both ends
UAJeep is offline   Reply With Quote
Glock Forum
